Home > Technical > Steering clonk |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
Could be the coil spring moving in it's seat. 2.4 90 XS
13th May 2009 10:23am |
Landy nut Member Since: 22 Dec 2007 Location: In hiding Posts: 154 |
CV joint or steering ball joint
13th May 2009 6:19pm |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
CV is like a loud clicking sound in the early stage (don't leave this to long or it will let you down at the worse time). A clonck could also be a bush gone on the front raidius arms.
13th May 2009 6:49pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4654 |
Could be a loose jack under the seat. Have a look in the seat box. 1982 88" 2.25 diesel
13th May 2009 9:42pm |
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 |
Check your swaybar connections. I had the same issue when one of the connecting bolts fell out.
Tim |
14th May 2009 12:14am |
