Home > Technical > Steering clonk
rangra
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Java Black
Steering clonk
Often when we are going round the corner (usually a sharp right but sometimes left) there is a clonk / a metal on metal sound.
Des anyone know what this could be? LAND ROVER DEFENDER 110 XS SW 2.4
Post #10813 13th May 2009 11:12am
Grockle
Could be the coil spring moving in it's seat. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #10818 13th May 2009 11:23am
Landy nut
United Kingdom 2006 Defender 90 Td5 PU Epsom Green
CV joint or steering ball joint
Post #10849 13th May 2009 7:19pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
CV is like a loud clicking sound in the early stage (don't leave this to long or it will let you down at the worse time). A clonck could also be a bush gone on the front raidius arms.
Post #10853 13th May 2009 7:49pm
spudfan
Ireland
Could be a loose jack under the seat. Have a look in the seat box. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #10864 13th May 2009 10:42pm
Tim_NZ
Australia
Check your swaybar connections. I had the same issue when one of the connecting bolts fell out.
Tim
Post #10870 14th May 2009 1:14am
