Home > Maintenance & Modifications > More lock required |
xatzhs Member Since: 12 Dec 2010 Location: Northumberland & Down South Posts: 258 |
Is it essential to have them on axle stands? Is it easy/safe enough to do it without? |
2nd Jun 2012 11:44am |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
I would not even contemplate this task without stands BM52 |
2nd Jun 2012 1:48pm |
mrandmrsh Member Since: 31 May 2010 Location: Huddersfield Posts: 692 |
All I did was crawl under the car as it was stood on the ground with the steering straight and screwed one side in then moved car back and fwd on full lock to see if I had gone too far/far enough. Then same with the other side. Done. No jacks, no stands just two 19mm spanners. C 2015 110 USW XS in Santorini with premium contrast leather seats in tan/black, black headlining and with Dual Finish alloys (in the garage, now on Wolf rims with Goodyear MT/Rs) 2012 '62' 2.2 X-Tech 110 USW now gone ... 1984 90 soft top with full roll cage, 200 tdi engine etc now sold 2012 USW XS 2.2 "FUU" now gone.... |
3rd Jun 2012 10:50pm |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 |
I believe it's another big difference to the circle with 30mm spacers and why I'm considering them. The wife will be even more impressed.......... 1951 80" S1 2.0
11th Jun 2012 9:03pm |
Question for me is how much more can you safely wind the lock stops in over and above a standard car on standard alloys with standard 235 tyres? If I was on 265 tyres I would think spacers would be critical but I am just not sure how much more you will get on standard set-up. Would love to know. C 2015 110 USW XS in Santorini with premium contrast leather seats in tan/black, black headlining and with Dual Finish alloys (in the garage, now on Wolf rims with Goodyear MT/Rs) 2012 '62' 2.2 X-Tech 110 USW now gone ... 1984 90 soft top with full roll cage, 200 tdi engine etc now sold 2012 USW XS 2.2 "FUU" now gone.... |
12th Jun 2012 11:10am |
Someone will answer this I'm sure but if I put a 30mm offset on the wheels (using spacers) I would hope to be able to wind in the stops by the same amount again 1951 80" S1 2.0
12th Jun 2012 8:36pm |
I used to have 235s on Boosts (ET33 offset) with 30mm spacers and adjusted stop - awesome improvement
Now I have 265s on Dotz Dakar rims with ET8 offset, no spacers and adjusted stops = almost as good. Zus have ET11 offset, so with no spacers and 235s or 265s and adjusted stop they should also be a good improvement over factory. Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
12th Jun 2012 10:35pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
mine rubs as i've wound the stops right in.
i cn turn round ok now |
12th Jun 2012 10:38pm |
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 |
Mine rubs when you turn left but not right... sounds like my stops are set a bit wonky then
Handy thread this one |
13th Jun 2012 1:05am |
xtreme Member Since: 05 Jul 2012 Location: United Kingdom Posts: 24 |
Did the same today, car 2 days old! Difference incredible!!! Thanks! |
5th Jul 2012 5:09pm |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 |
Had 30 mm spacers fitted and stops done Tuesday wow what a difference almost drive-able in car parks now It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
5th Jul 2012 6:32pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
im running 35 inch simex with no rubbing
and it turn great can get right round a mini roundabout easy steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
5th Jul 2012 7:57pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20473 |
How about if the stops are set equally already counting the turns exactly and equally on both sides surely that would do the same as well. And just check after it's not over done.. If it is reapeat but anti clockwise. I yet have to have a go at this yet. No Guts, No Glory.
5th Jul 2012 8:36pm |
Finally got round to checking and adjusting the steering lock stops today but I find that it's pretty much to the maximum I'd be happy to have it already. I can't help but think having it to close is not a good idea after all when tyre's are muddy it will bind between the tyre and the radius arm and if you were un-lucky enough to get a small stone in that gap it wouldn't be good so I'm leaving mine alone. No Guts, No Glory.
15th Jul 2012 11:22am |
