Home > Maintenance & Modifications > Hydraulic winch |
mog Member Since: 27 Feb 2011 Location: Århus Posts: 26 |
Hello Guys
Does anybody have experience with hydraulic winches and are abel to offer some advice. My defender has AC and that means that (as far as i can see) that I need a PTO system (transfer box) I have only been abel to find one compagny that offer hydraulic systems (http://www.firstfour.co.uk/) Can anyone direct me to alternatives for price comparison Thankyou in advance Mog www.landroving.dk |
14th May 2012 7:44am |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
If i was going to go Hyd,, would be looking at Red Winch's
http://www.red-winches.com/index.html Very helpfull guys,, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
14th May 2012 8:06am |
McS Member Since: 05 Oct 2009 Location: Banbury Posts: 686 |
I've played with plenty hydro systems over the past few years, both competition spec and industrial/military applications.
Your selection of brand is really down to what your application is (as well as price and personal preference of course). Have a look a Red Winches, Milemarker, Goodwinch (David Bowyer) and Saley winches. In terms of how you drive it, you could indeed use a PTO system (in which case why not look at a PTO driven winch like the Superwinch H14 instead?) or you could use a belt or prop-driven hydro pump. Your particular engine setup will dictate how you mount the pump but the presence AC should not cause an issue. If you need anything more, please fire away! Regards, Ross The Scotia Winch Challenge |
14th May 2012 8:09am |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
Email Peter at First Four and see what he suggests. He has a Red on the front of his Puma. |
14th May 2012 9:53am |
thanks guys
I will have to look into the mechanical winch that also seems to be a vey reliable solution |
14th May 2012 10:34am |
I'm not overly enamoured by the red winches to be honest. Very expensive for what they are. For industrial type applications, the goodwinch and milemarker offerings are much better value for money and for competition stuff there's no beating Saley's product without going down the custom build route....
Just my two pence worth. Ross The Scotia Winch Challenge |
14th May 2012 1:55pm |
