Home > Maintenance & Modifications > Hydraulic winch
mog
Denmark 2009 Defender 110 Puma 2.4 SW Alpine White
Hydraulic winch
Hello Guys
Does anybody have experience with hydraulic winches and are abel to offer some advice.
My defender has AC and that means that (as far as i can see) that I need a PTO system (transfer box)
I have only been abel to find one compagny that offer hydraulic systems (http://www.firstfour.co.uk/)
Can anyone direct me to alternatives for price comparison
Thankyou in advance
Mog
www.landroving.dk
Post #144842 14th May 2012 7:44am
TJ101
If i was going to go Hyd,, would be looking at Red Winch's
http://www.red-winches.com/index.html
Very helpfull guys,, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #144850 14th May 2012 8:06am
McS
I've played with plenty hydro systems over the past few years, both competition spec and industrial/military applications.
Your selection of brand is really down to what your application is (as well as price and personal preference of course). Have a look a Red Winches, Milemarker, Goodwinch (David Bowyer) and Saley winches.
In terms of how you drive it, you could indeed use a PTO system (in which case why not look at a PTO driven winch like the Superwinch H14 instead?) or you could use a belt or prop-driven hydro pump. Your particular engine setup will dictate how you mount the pump but the presence AC should not cause an issue.
If you need anything more, please fire away!
Regards,
Ross The Scotia Winch Challenge
Post #144851 14th May 2012 8:09am
wslr
Re: Hydraulic winch
mog wrote:
Hello Guys
Thankyou in advance
Mog
www.landroving.dk
Email Peter at First Four and see what he suggests. He has a Red on the front of his Puma.
Post #144879 14th May 2012 9:53am
mog
thanks guys
I will have to look into the mechanical winch that also seems to be a vey reliable solution
Post #144883 14th May 2012 10:34am
McS
I'm not overly enamoured by the red winches to be honest. Very expensive for what they are. For industrial type applications, the goodwinch and milemarker offerings are much better value for money and for competition stuff there's no beating Saley's product without going down the custom build route....
Just my two pence worth.
Post #144929 14th May 2012 1:55pm
