![]() | Home > Td5 > Noisy fuel pump |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 587 ![]() ![]() ![]() |
She's booked in on the 16th, we'll see what happens.
New Bearmach fuel pump fiitted and noise has gone away.
Had to remove tank as there's a stiffening rib under the floor directly over the pump. Would have weakened the floor cutting through it. ![]() |
Arbman Al Member Since: 04 Jan 2012 Location: Surrey Posts: 80 ![]() |
If the injector seals are leaking, does the diesel not get into the engine oil, and so show up by giving a higher reading on the engine oil dipstick? 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
No, it allows the air that is compressed in the cylinder back into the fuel system.
The seals would have to be very bad, or have a cracked head to get diesel in the fuel. |
I've had an extremely noisy pump for the past 2 years, the injector seals went along with oil in the injector harness. I had tose done and since then just lived with it, if it packed up then I'd change it, wasn't going through the rigmarole of tank out if I didn't have to. I changed the pressure regulator seals about a fortnight ago and that didn't make a difference to the pump noise but on Tuesday night I filled it up to allmost full, I don't often put in much more than half a tank but as I had a long run yesterday I didn't want the hassle of getting diesel through the day. Ever since then it has run quietly even when the level in the tank is down low again. Now we'll see if it's on it's last legs or it has gone through a self healing process
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 ![]() ![]() |
Hello all, I had the same problem with a noisy pump that had the internal filter clogged, I cleaned and works perfectly now.
It also starts whining when the fuel filter is dirty. Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
Thanks for the reply. Think I'll change the seals as only getting 16mpg ![]() Being a 130 tipper it is easy to get to the pump ![]() Noticed that the filter head had broken away from the chassis, what is the best place to buy on e from? Cheers...Al 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
The 'so called' OE seals I've just had put in mine have given out after two weeks.
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
iv just fitted new seal in the disco and the pump has become noisy they were from ebay ?
could this be down to the seals 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
I got mine via fleabay but they did come from one of our site sponsors(LRS). It's got to be the first time my Defender hasn't marked it's terratory for years
well after doing about 14 miles the disco has stopped twice and diesel is getting in to the oil ?
the only thing i have done is the injector seals ? bought off ebay as genuine but were loose when arived not packeted is there anything you can do wrong when fitting them ? steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Same here. ![]() My fitters say they were the wrong colour for genuine. ![]() |
