Home > Puma (Tdci) > Best Snorkel
Page 6 of 6 <123456
Berndv
Netherlands 2008 Defender 90 Puma 2.4 SW Auto Epsom Green
The piece gives some usefull information indeed, but it was written for a td5, not a tdci and only gives some info on the bits right behind the air intake. So is it the same for a tdci? and is this indeed all that is needed or do things need to be done further down the air way?
The mantec is mainly bought for looks as I do not intend to wade much deeper than the official 50cm. But in the occasion that I end up in water that is deeper than anticipated, I want it to be properly sealed.
Post #167138 9th Sep 2012 4:13pm
K9F
Try doing a search or two yourself....
Last one from me....
https://www.defender2.net/gallery/thumbnails.php?album=26
Also the suppliers advertise.... "Mantec Raised Air Intakes are supplied with a fitting kit and instructions." Should the instructions be lacking in detail and if all else fails phone them! Or just seal everything you deem to be at risk of leaking underwater in the airfilter box.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #167140 9th Sep 2012 4:24pm
Berndv
Thanks K9F. I have done quite a few searches already and indeed I had found that one myself but it doesn't say anything about any work needed behind the wing. i.e. from the inner wing to the air filter (and beyond?) so it didn't help me with my question.
All instructions I found are for the outside as are the instructions that came with it. That should be enough to qualify it for an RAI as that is what mantec is selling it for. I was wondering what more needs to be done to seal it more like a snorkel.
As I couldn't find anything one could also conclude that no more is needed and that it is just a mix-up of the words snorkel and RAI.
Cheers,
Bernd
Post #167148 9th Sep 2012 4:46pm
K9F
Maybe you could 'adapt' the Safari snorkel fitting instructions and seal your own to match perhaps?
http://www.google.co.uk/#q=safari+snorkel+...mp;bih=575 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #167156 9th Sep 2012 5:44pm
Page 6 of 6 <123456
