![]() | Home > Puma (Tdci) > Best Snorkel |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20754 ![]() ![]() |
How about a poll for each make?
Ah, fair enough.
Oh no, not another one ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Yeah true about the poll I think most people will not want to say their snorkel they bought was no good ![]() Zag, I thought that the LR genuine one was still made by Mantec? It looks the same after all. I know it's not a Snorkel but I bought some Mantec roof bar's not long ago and I've been very pleased with them. |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5025 ![]() ![]() |
Yes didn't say Mantec no longer make the LR genuine one. The LR one is different, has a smaller hat and LR logo on it
Ah I see. �300 something though ![]() |
NO THEY DON'T! Well errr not now anyway. ![]() Might remind me to hit the preview button! Agree with Safari all the way. Maybe we should start stocking them |
If i'm being shot at with a 4.5kg dart the last thing I'm going to worry about is the snorkel ! ......
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2468 ![]() ![]() ![]() |
Safari�s design causes a lot of air charge loos. So flexi mantec with a safari top
![]() ............................................................. Earth first. Other planets later |
Really? Got any details to explain that? Darren
Just look at the pics. I did a kind of experiment where at the end I filled the hollow bottom and sides giving a more "gentle" shape so the air passed through more freely. So at the end I got more air (or at least faster).
However, if all this made any big difference in performance?..... ![]() Something to consider is the volume of air sucked by the engine and how much air passes through the RAI at any speed. Puma 110" SW ............................................................. Earth first. Other planets later |
Well I am no internal combustion engineer expert but will make the following observations.
Safari Snorkels have been making snorkels or RAI for about 30+ years and are well respected on their home territory Australia for the quality of their products. Air charge loos? (sic) Now if a diesel or petrol engine does not receive sufficient air then it will not run properly and in the case of diesel engine would probably emit lots of white smoke being unburnt fuel.. For maximum volume flow through any system you are best off with as laminar flow as possible which means gentle bends, smooth internal surfaces etc. However surely a diesel engine will only suck in as much air as it needs? Too much air fed to a diesel engine would result in???? Too little air and the result would be????? However once the air has flown through whatever brand of RAI is fitted it normally hits an AIR FILTER. The type of air filter fitted and its condition would probably have a greater effect then the shape of the most popular RAI. The so called performance filters allow more air to flow through them due to their bigger pore size. Surprising enough the Aussies have done research into the filtration, air flow etc through various air filters and surprisingly the OEM ones come out better for 4x4 then the so called performance filters. If running a performance car in a clean environment then yes a performance filter might have some benefit. Brendan |
Well, Safari people told me they have not done any research regarding their RAIs.
It is plenty of literature about charge or load loss (yes...not loos). Puma 110" SW ............................................................. Earth first. Other planets later |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 ![]() ![]() ![]() |
I like the look of these Mantec ones - I prefer the more traditional look to the big block of plastic
![]() And you don't have to drill the wing either ![]() ![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
Just fitted a flexi lite one to mine. Bloody right faff. Looks cool though. A friend just asked me what it's for, it's for dusty sandy environments. The reply was "are we in for dusty weather then?"
Don't think it matters which one you choose, cos you'll never use it anger. Unless you have a trip to morocco planned. |
