Home > Maintenance & Modifications > Anti Roll Bars
Page 4 of 5 <12345>
df1
What make did you use ?
Post #298409 13th Jan 2014 7:51pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
The 30mm front is a MOD Snatch upgrade roll bar kit made by Ricardo.
The rear is a Scorpian / Extreme 4x4 25.4mm kit
Post #298423 13th Jan 2014 8:04pm
munch90
are Terrafirma anti roll bars any good .. any body fitted them and what do you think of them ?
Post #298503 13th Jan 2014 10:38pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
If Terrafirma is the same as Britpart, then it's what I put on mine. Seems okay, time will tell if they're reliable, but I'm quite pleased so far.
Post #298508 13th Jan 2014 10:44pm
rustandoil
After months of deliberation i decided to go with the X-Eng rear anti roll bar set up, first impressions are very promising Thumbs Up
Post #304885 3rd Feb 2014 11:38pm
df1
Have you fitted a front ARB ?
Post #304938 4th Feb 2014 9:00am
rustandoil
Yes I fitted a std 25mm front ARB a few months back Thumbs Up
Post #305004 4th Feb 2014 1:03pm
smb
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Eddie,
You shouldn't be disappointed. However, I highly recommend you paint it all in ACF50 as the electroplating soon disappears and starts looking in a bad way. I will post what it is like after 30,000miles/12 months and it doesn't look good. It still works though!!
Post #305008 4th Feb 2014 1:21pm
jthedefender
United Kingdom 2002 Defender 90 Td5 Tomb Raider LE Bonatti Grey
o4dn wrote:
Quick follow up, I've ordered and fitted anti-roll bars,and as you said, handling is definitely much better on road and fitting was an easy job actually, no drilling needed, everything was there in place ready on the axles and chassis.
I do have one concern though, on the rear, I find the ball joint assembly to be fairly bent toward the front which I find odd, as if the anti-roll bar was too long.
Is this normal? I don't have access to a vehicle with ARB mounted from factory to use as a reference.
[/img]
Very old thread I know, but I have exactly the same issue, anti-roll bar joints are pushed towards the front of the car and pretty much touching the axle, that cant be right?
Did you ever find out the issue or fix it?
Post #1054355 10th Dec 2024 6:15pm
o4dn
Nope, I left it like that ever since. No problem whatsoever.
On the front, though, it was touching the axle, so I enlarged the mounting holes on the bracket so I could move it back slightly. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #1054357 10th Dec 2024 6:26pm
jthedefender
Ok cool. Thanks for coming back to me so quickly.
I had the garage refit it but they didn’t do the nuts up and lost a polybush and the bolt/washer/nut on one side so was deciding whether to just take it off as never really noticed any difference with it on.
Really odd as it was originally on the car when I got it and im sure it wasn’t that close to the axle before. I was going to fit the Terrafirma larger one but couldn’t get it to go on as the joints were rammed against the axle. So thought I’ll put the old one back on but that’s now pretty much the same? Unless I’m missing something…
Thanks again.
Post #1054358 10th Dec 2024 6:47pm
Mining Subsidence Stu
United Kingdom 1991 Defender 90 200 Tdi HT Caledonian Blue
Presumably you lot with ARBs are using them on 90s? My 110 was fine with braking in a a not straight line, my 90 is borderline dangerous.
Post #1055775 28th Dec 2024 4:46pm
jst
Have arbs on my 90, 110 and 130. Biggest difference was upgraded rears on 110 and 130. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1055802 28th Dec 2024 9:35pm
Chicken Drumstick
Lack of maintennce?
Post #1055806 28th Dec 2024 11:34pm
revd
not lack of maintenance - shorter wheelbase of the Ninety trades the stability of a 110 for manoeuvrability which can lead to a nasty moment sooner if things get out of shape
Post #1055812 29th Dec 2024 12:20am
Page 4 of 5 <12345>
