Home > Maintenance & Modifications > Anti Roll Bars |
df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 |
What make did you use ?
13th Jan 2014 6:51pm |
are Terrafirma anti roll bars any good .. any body fitted them and what do you think of them ?
13th Jan 2014 9:38pm |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 546 |
If Terrafirma is the same as Britpart, then it's what I put on mine. Seems okay, time will tell if they're reliable, but I'm quite pleased so far.
13th Jan 2014 9:44pm |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 757 |
After months of deliberation i decided to go with the X-Eng rear anti roll bar set up, first impressions are very promising
3rd Feb 2014 10:38pm |
Have you fitted a front ARB ?
4th Feb 2014 8:00am |
Yes I fitted a std 25mm front ARB a few months back
4th Feb 2014 12:03pm |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
Eddie,
You shouldn't be disappointed. However, I highly recommend you paint it all in ACF50 as the electroplating soon disappears and starts looking in a bad way. I will post what it is like after 30,000miles/12 months and it doesn't look good. It still works though!! |
4th Feb 2014 12:21pm |
jthedefender Member Since: 02 Dec 2013 Location: Watford Posts: 2 |
Very old thread I know, but I have exactly the same issue, anti-roll bar joints are pushed towards the front of the car and pretty much touching the axle, that cant be right? Did you ever find out the issue or fix it? |
10th Dec 2024 5:15pm |
Nope, I left it like that ever since. No problem whatsoever.
On the front, though, it was touching the axle, so I enlarged the mounting holes on the bracket so I could move it back slightly. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
10th Dec 2024 5:26pm |
Ok cool. Thanks for coming back to me so quickly.
I had the garage refit it but they didn’t do the nuts up and lost a polybush and the bolt/washer/nut on one side so was deciding whether to just take it off as never really noticed any difference with it on. Really odd as it was originally on the car when I got it and im sure it wasn’t that close to the axle before. I was going to fit the Terrafirma larger one but couldn’t get it to go on as the joints were rammed against the axle. So thought I’ll put the old one back on but that’s now pretty much the same? Unless I’m missing something… Thanks again. |
10th Dec 2024 5:47pm |
Mining Subsidence Stu Member Since: 06 Mar 2024 Location: Cornwall Posts: 24 |
Presumably you lot with ARBs are using them on 90s? My 110 was fine with braking in a a not straight line, my 90 is borderline dangerous.
28th Dec 2024 3:46pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8131 |
Have arbs on my 90, 110 and 130. Biggest difference was upgraded rears on 110 and 130. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
28th Dec 2024 8:35pm |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 763 |
Lack of maintennce? |
28th Dec 2024 10:34pm |
revd Member Since: 20 Apr 2024 Location: England Posts: 155 |
not lack of maintenance - shorter wheelbase of the Ninety trades the stability of a 110 for manoeuvrability which can lead to a nasty moment sooner if things get out of shape
28th Dec 2024 11:20pm |
