Home > Wheels & Tyres > Spare wheel location
Page 2 of 3 <123>
MadTom wrote:
I have new BFG MT KM2 255/85/R16 on a "wolf copy" disk and they are 40kg each. Shocked Next step will be LR original Alu.
Should of added tyre is a 235/85/R16 so your extra weight might be mostly in the tyre. Wheel is steel.
Post #321693 5th Apr 2014 11:35am
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Don't forget: rubber smells when new.
I bought a rubber sheet to put in the back I could cut to size myself. I've just recently started using it after leaving it outside for a full year to get the small out. It saw all 4 seasons.
I suspect you'll have the same issue with your tyre.
Post #321851 6th Apr 2014 8:32am
leealanr
2013 Defender 110 Puma 2.2 XS CSW Santorini Black
LandRoverAnorak wrote:
Blimey, Supacat, are they your feet? Shocked
Laughing
Post #323773 14th Apr 2014 10:34pm
X4SKP
Hello All
Can I have your views on the options for mounting a non-standard spare wheel at the rear of a Defender
Currently I have X4 20x9.5 Land Rover LRX wheels fitted with Cooper Zeon LTZ (275 60R20) Tyres
and
A conventional steel wheel & tyre spare giving a usable 'get me home or to a garage' option
I view the spare as similar to a space saving spare fitted to many cars currently, you really wouldn't
want to go that far on it. Also I know that it is 'curtail' to ensure that the diameter of the spare should
match or be very close to the other wheels (to within a few mms) so that undue stress is not put on the
differential / gear-train. There is also in my case the requirement to take off a wheel spacer in order
to use the current spare.
So I have managed to source a single ET50 version of this wheel...
The wheel is now discontinued at this size (ET53 is still available)...
I have been looking at various wheel carriers and whilst I like the Nakatanenga SS carrier
at the wrong side of £500 it's too expensive for me (with other projects planned for the 90)
The Mantec option looks good, and will also fit 'around' the NAS rear step. I would probably strip it and
refinish it inline with the other accessories on my 90 so that they all have a longer life (although the
Mantec reviews well in this aspect it would appear).
I have been considering another option which I would be interested to hear if anyone on here as actually
done, with success. Thumbs Up
I am considering strengthening the rear door and probably fit a gas strut to control its closure.
Door card off, internal and possibly external plating to minimise the 'flex' and ultimate breaking of the
rear door is the aim. All of this wont add to the standard strength of the door hinges. Currently I don't
know the weight of my alloy + tyre wheel, but I would be surprised if they were significantly heavier than
the steel wheel and 'tractor' like tyre fitted.
So the question... is rear door strengthening a good option or a non starter Question
Thanks SKIP
Post #331193 15th May 2014 10:54am
K9F
The Nakatanenga rear door strut is a worthwhile modification.....The rear door will not need strengthening with one of these. Thumbs Up
http://www.defender2.net/forum/topic20812.html?highlight=strut If you go through life with your head in the sand....all people will see is an ar5e!!
Post #331224 15th May 2014 2:40pm
X4SKP
Hello K9F
Thanks, I have been looking at the Nakatanenga door strut you suggest.
It looks as though it requires the door card to be 'modified' (cut down) to allow its 'articulation'
That's ok even though I have a re-trimmed interior and adds a bit more work to install well, I think that
it is a good mod' to consider. Whilst the door is exposed I will assess if I can get any metal in there
that will help, but its good to hear that you think this may not be necessary.
Thanks for your help. SKIP
Post #331226 15th May 2014 2:57pm
K9F
No door card modification required either on a 2.4 Puma. One of the best modifications you can do in my book. Then again my spare is heavy and BIG!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #331228 15th May 2014 3:35pm
X4SKP
Thanks K9F
Good to hear... so this is just a cut away to show the hidden location of the strut Question SKIP
Post #331237 15th May 2014 4:44pm
mk1collector
The strut you have to cut away for is pre 2002 and the post 2002 doesn't need the trim cutting according to 4x4 overlander site (site sponsor on here) pm Brendan and he'll give you all the info you need
Post #331248 15th May 2014 5:38pm
X4SKP
Hello mk1collector
Thanks... you are correct Thumbs Up
Have you got one, and if so what do you think of it Question
It's almost on my list Exclamation SKIP
Post #331267 15th May 2014 7:26pm
mk1collector
I haven't yet but it is on my list to do aswell. First for me is a nakatenenga wheel carrier
Post #331271 15th May 2014 7:46pm
Mass Debater
United Kingdom 1984 Defender 90 V8 Petrol SW Caledonian Blue
Has anyone ever seen a Defender with the spare mounted in front of the grill ?
I think it could look cool and I believe the alloys I have would allow enough air flow to keep the engine cool.
Regards the Punctureseal
My 90's aftermarket wheels/tyres came as a set of 4, I thought there is no way these would ever pick up a puncture.
Then I went wobbly and installed "Puncturesafe" which is when I was convinced my wheels went wobbly.
I also have it in the RR and recently had the tyres (c/w Puncturesafe) fitted to some re-powder coated alloys.
The alloy refurbishers could not get the wheels balanced, and they and other tyre fitters they consulted, blame the sealant.
However, I have it in my motorbike and have never experienced wheel imbalance.
On my bucket list is brand new 110 USW.
I want to mount a motorcycle carrier to the back, so the spare wheel needs to come off the rear door.
If I get a roof rack, it will probably go on there, but I really fancy the front grill idea.
Then again, I could just grow a pair and leave the spare at home.
The AA can always get to the locations I intend going to Thumbs Up LR 90 CSW V8 LPG
LR 127 ex RAF V8 LPG
RR Classic V8 Not LPG (ouch)
Post #331690 18th May 2014 3:23am
Only on a military one:
Post #331694 18th May 2014 6:15am
Mass Debater
Thanks for the photo. I like, although I'm sure I could mount one a bit more securely than that Thumbs Up LR 90 CSW V8 LPG
Post #331936 19th May 2014 4:44am
The bull bar on the Snatch vehicles has a plate welded into the centre to take the wheel mounting. They do come up on EBay from time to time but the legalities of fitting one to road registered vehicle would be questionable.
Another military variant on the SAS Pink Panthers:
and to show other makes have them as well:
Post #331949 19th May 2014 7:39am
Page 2 of 3 <123>
