Home > Wheels & Tyres > Spare wheel location
Page 3 of 3 <123
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
Mine is flat on the floor in my 90, with the off-road box on top.
My 35" Simex fits there too. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #331965 19th May 2014 7:54am
Mass Debater wrote:
Has anyone ever seen a Defender with the spare mounted in front of the grill ? ...
I think that your insurance company might have something to say about that ("you must be joking" being a strong possibility)!
Post #331971 19th May 2014 8:02am
munch90
X4SKP wrote:
Hello All
Can I have your views on the options for mounting a non-standard spare wheel at the rear of a Defender
Currently I have X4 20x9.5 Land Rover LRX wheels fitted with Cooper Zeon LTZ (275 60R20) Tyres
and
A conventional steel wheel & tyre spare giving a usable 'get me home or to a garage' option
I view the spare as similar to a space saving spare fitted to many cars currently, you really wouldn't
want to go that far on it. Also I know that it is 'curtail' to ensure that the diameter of the spare should
match or be very close to the other wheels (to within a few mms) so that undue stress is not put on the
differential / gear-train. There is also in my case the requirement to take off a wheel spacer in order
to use the current spare.
So I have managed to source a single ET50 version of this wheel...
The wheel is now discontinued at this size (ET53 is still available)...
I have been looking at various wheel carriers and whilst I like the Nakatanenga SS carrier
at the wrong side of £500 it's too expensive for me (with other projects planned for the 90)
The Mantec option looks good, and will also fit 'around' the NAS rear step. I would probably strip it and
refinish it inline with the other accessories on my 90 so that they all have a longer life (although the
Mantec reviews well in this aspect it would appear).
I have been considering another option which I would be interested to hear if anyone on here as actually
done, with success. Thumbs Up
I am considering strengthening the rear door and probably fit a gas strut to control its closure.
Door card off, internal and possibly external plating to minimise the 'flex' and ultimate breaking of the
rear door is the aim. All of this wont add to the standard strength of the door hinges. Currently I don't
know the weight of my alloy + tyre wheel, but I would be surprised if they were significantly heavier than
the steel wheel and 'tractor' like tyre fitted.
So the question... is rear door strengthening a good option or a non starter Question
Thanks
in the post here it says you have a standard steel as a get you home spare
that's ok but if you got abs/tc the spare needs to be the same rolling radius as other non standard wheels still fitted to keep wheel speeds the same and also better for diff
doesn't have to be same size just same rolling radius
sorry if you knew this but thought it may help others
Post #331974 19th May 2014 8:05am
X4SKP
Thanks munch90
Yes (you're right and I did know) my spare is the same diameter / rolling radius...I just don't like it.
I am planning a long distance trip across Europe and just like the idea of having a duplicate spare,
rather than doing umpt'een kms looking for a fix / new tyre if I get a problem.
On my last 90 I bought 5 matching alloys + BFG tyres and in 19 years used the spare once, when a
slow puncture (faulty valve) needed fixing, so I am expecting very little possibly even no use...
but you never know! SKIP
Post #331983 19th May 2014 8:50am
How have you secured it from moving?
Post #331998 19th May 2014 9:51am
Page 3 of 3 <123
