Home > My Defender > My 110DC has a new buddy ! |
still away being powder coated ... will get some KM2's or STT's fitted and pop a photo up
17th Sep 2012 8:44pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Got some more done today (no pics) and have finally given up on fitting the SE wheel carrier.
Having now got the correct wheel carrier for the 90 with the correct length arms the thing still does not fit Local body shop modified the bottom body bracket so it would fit correctly - so far so good. Put the bracket on the door and put the main carrier on to position the top body bracket. After three of us spending a good couple of hours trying to get it to fit we failed. The door bracket is half an inch to low and to drill the door would mean that new crush tubes are needed etc. The body shop said it would not be a good idea to drill new holes in the door as they would be way too close to the existing mounts and would probably give way. The bracket can't be drilled as the holes are right at the bottom. We then thought about plating the door but before starting we held the mount in the correct position to at least see if the top body bracket would fit. It would if the centre door hinge was removed It is destined for the skip Fitted all the remaining insulation in the front and started making up new looms for the extra instruments. Invested in some proper ratchet crimpers from Polevolt, making connections up is now a pleasure Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
18th Sep 2012 5:05pm |
SE - steptoe edition ?? |
18th Sep 2012 5:10pm |
Might as well be Steve, it would probably fit on a cart
Safari Equip. They must have sold hundreds of the things so I (and quite a few others) can't work out why it will not fit on the my TD5. If it did fit the spare wheel would sit so low that I think it would be useless, the bottom of the tyre would in line with the centre of the rear crossmember and I am guessing the nato hitch would have to be removed. I can't justify the cost of a full chassis mount version on this vehicle so it looks like the spare will have to stay in the back or I will just have to put the original LR door mount back on. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
18th Sep 2012 5:24pm |
TDS 9.5 winch fitted this afternoon and all plumbed in
Picking up a Disco transfer box tomorrow so I can have more relaxed cruising. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
22nd Sep 2012 4:29pm |
An update on progress, no pictures - you will find out why later
All paintwork sorted and bits bolted back on. Duff modular wheels replaced by Craddocks and tyres swapped over. First class service from Craddocks First Four modified winch bumper fitted and TDS 9.5 winch fitted and plumbed in. Turbo hoses changed for silicon ones, the old rubber ones were shot. Mud centre panel fitted to the 2002 type radio housing and clock, volt meter and boost gauge fitted. Boost still not plumbed at the gauge end as myself and the indy, where it currently is, still can't work out how the pressure pipe fits on the back of the VDO gauge. Given up on the spare wheel carrier, life is to short and I have far better things to do Spare wheel is going to live in the back but I wanted the ability to carry something in the back other than a spare wheel. Solution was found with a lot of help from Peter at First Four, a set of Mantec 110 rear wheel arch cages and shelves - they will fit Cages will give enough height to allow the spare wheel to live under the shelves and combined with the dog guard will give a good storage/load area. Not seen them yet as Peter delivered them to the indy where the 90 currently is, the intention was to fit them this weekend but ........ Sent the 90 in to have the injector seals changed, the state of the old ones can be seen here http://defender2.net/forum/topic15669.html Intention was to collect the 90 tomorrow, fit the cages etc and finish it off. Then came the email at lunchtime They were running the 90 this morning and there was still the smoke problem. The Indy had some extra mechanics in helping with some other work and they asked their opinion as to what the problem may be - diagnostics showed no problem. One of them was suspicious that it was turbo related and removed the front of the turbo to investigate and all became clear. On revving the engine the turbo was not spooling up correctly, there was a lag of a few seconds. Can't tell you the exact problem but it sounds like the bearings have expired and when the turbo eventually decided to spool it resulted in the blue/grey smoke. After much debate it was decided to fit a new turbo rather than get the old one fixed - it will be delivered to the indy on Monday. Expensive bill on the way but I am glad they found the turbo problem, I would not have fancied it expiring in the middle of Salisbury Plain ! There is light at the tunnel and I will post pictures of the finished article when it returns next week Going down the pub now whilst I can still afford a pint Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
19th Oct 2012 5:49pm |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 |
A broken turbo on a TD5 is the best time to upgrade! Chop it in for a VNT
19th Oct 2012 6:07pm |
Did think about that but as it is going to be used mainly offroad I am not sure I would get the true benefit.
If the Puma throws its turbo then a VNT is a no brainer Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
19th Oct 2012 6:11pm |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
Microcat is showing £1200.19 for a brand new Genuine Part unit, Bob. Luckily, yours will be much less.
19th Oct 2012 9:29pm |
Almost finished
Centre dash modified with a Mud plate. Clock moved from main console to allow rev counter to be fitted plus volt and boost gauges added. Click image to enlarge Mantec cages and shelf added, spare wheel lives under the shelf. Small mods needed to get them to fit - they are for a 110, had to shorten the side cages by about 1.5" to allow them to fit with the dog guard (top is not fitted in the pictures). They will fit into a 90 without a dog guard without any mods. Click image to enlarge Click image to enlarge Front end ready for action Click image to enlarge Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
3rd Nov 2012 4:19pm |
v40mav Member Since: 25 Aug 2008 Location: UK Posts: 206 |
Looking very good
Well worth the time and effort Defender 110 County SW Disco 3 HSE Freelander 2 HSE - SOLD going back to a car www.lothian4x4response.org |
3rd Nov 2012 4:36pm |
hey Bob - you've been really busy - your truck looks ace! coming out to play on the 25th ?
4th Nov 2012 8:29am |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10380 |
Nice lil project, looks well
4th Nov 2012 9:04am |
Thanks Steve Not sure about the 25th, my relatives are here from the US until Dec 15th so I am organising things around them at the moment Should have plumbed the boost gauge today having got all the correct bits now from a local pneumatic parts supplier but frost bite got me before I could finish Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
4th Nov 2012 7:52pm |
