![]() | Home > Wheels & Tyres > mantec spare wheel carrier |
I'll take a pic of mine once it stops raining.
They changed the layout of the bolts and Mantec made a new plate so that you didn't have to drill any holes in the back door - just use the in-situ fittings. You could always call them and I'm sure they'll send out the correct part for the later door. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 514 ![]() ![]() ![]() |
Call Mantec and ask to speak to Kevin Brayne (0247 6395368) he will help you. Cogito ergo sum
beetroot Member Since: 15 Dec 2008 Location: manchester Posts: 41 ![]() |
thanks, Mantec are sending one out.
david mitchell Member Since: 01 Jul 2012 Location: Meath Posts: 419 ![]() ![]() ![]() |
![]() Click image to enlarge i emailed ben at flatdog these pictures, he said mantec wheel carrier would not fit ![]() ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Nick-St Member Since: 23 Apr 2013 Location: Surrey Posts: 267 ![]() ![]() ![]() |
It's pretty tight with the standard step bumper - can't really see yours is much different though...
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6661 ![]() ![]() ![]() |
I would invert the nut and bolt, or use a different locking mechanism instead of the nylok, if that's the issue.
Good idea to invert the bolt, thanks
