Home > Wheels & Tyres > mantec spare wheel carrier
beetroot
does anybody have a pic of a mantec swing away spare wheel carrier fitted to a late defender with a one piece rear door?
I have swaped the rear door on my 50th to a late type, but the original mantec metal plate that bolted on to the old spare wheel carrier mounts is the wrong size for the new one piece door. I could just do with seeing what it is meant to look like so i can fabricate something up.
Thanks.
Post #9836 17th Apr 2009 7:20am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
I'll take a pic of mine once it stops raining.
They changed the layout of the bolts and Mantec made a new plate so that you didn't have to drill any holes in the back door - just use the in-situ fittings.
You could always call them and I'm sure they'll send out the correct part for the later door. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #9839 17th Apr 2009 8:01am
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Call Mantec and ask to speak to Kevin Brayne (0247 6395368) he will help you. Cogito ergo sum
Post #9849 17th Apr 2009 12:35pm
beetroot
thanks, Mantec are sending one out.
Post #9859 17th Apr 2009 1:43pm
david mitchell
Ireland 2003 Defender 90 Td5 HT Epsom Green
i emailed ben at flatdog these pictures, he said mantec wheel carrier would not fit Big Cry as the nas step is not original or a britpart. what do you think? i would have liked a mantec one. ive no idea what make is on the landy as was like that when i got her. any ideas of what wheel carrier would fit my defender? i would appreciate any help. Bow down
Post #263081 2nd Sep 2013 10:38am
Nick-St
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
It's pretty tight with the standard step bumper - can't really see yours is much different though...
Post #263084 2nd Sep 2013 11:20am
Martin
Site Admin
I would invert the nut and bolt, or use a different locking mechanism instead of the nylok, if that's the issue.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #263086 2nd Sep 2013 11:21am
david mitchell
Good idea to invert the bolt, thanks Thumbs Up
Post #263130 2nd Sep 2013 2:16pm
