Home > Puma (Tdci) > Is it possible for front seats to go further back?
W11LLX
Is it possible for front seats to go further back on 110 xs?
Post #9594 10th Apr 2009 7:43am
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Post #9595 10th Apr 2009 7:52am
W11LLX
thanks for that cob, I will get on to it, cheers mate 4 a quick response
Post #9596 10th Apr 2009 8:00am
Grockle
We have some in ours there good quality and make a big difference 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #9599 10th Apr 2009 9:09am
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
Look also this topic from the past:
http://www.defender2.net/forum/post5794.html#5794
There are pics of DIY extensions rails. Janusz
www.yahodeville.com
Post #9628 11th Apr 2009 10:55am
Rob A
Brazil 2008 Defender 130 Puma 2.4 HCPU Alpine White
Thanks Cobs for the mudstuff site, been looking for a simple solution like these rails for a while and there is lots of other cool bits and pieces there too. Well worth a look!!! Thumbs Up
Rob. 130 HCPU 2.4TDCi
110 300TDi
Post #9629 11th Apr 2009 2:12pm
philp
2008 Defender 90 Puma 2.4 HT Tonga Green
I put a few washers on the seat bolts underneath the existing rail raising it 20mm or so.
You will need 4 slightly longer "grade 8.8" bolts which you can get from a decent hardware shop which along with the washers shouldn't cost more than £2 for the lot.
That gets the seat back an inch or so,and saves a few quid. Thumbs Up
Post #9631 11th Apr 2009 2:50pm
MK
I did the same! Puma 110" SW
Post #9634 11th Apr 2009 4:39pm
Rob A
I did the same!
Think I'll try that too . . . .
Thanks Thumbs Up 130 HCPU 2.4TDCi
110 300TDi
Post #9652 12th Apr 2009 11:36pm
Rob A
Phil, finally got round to raising the seats, but could not push them back any further due to what looks like a built in "bump stop" inside the tubing. How did you get round this? All I can think of is putting two pieces of wood/metal under both sides of the assembly to bring it higher and then bolt onto that a few inches further back. It would have to be strong though. Any ideas? Confused
Thanks
Rob 130 HCPU 2.4TDCi
110 300TDi
Post #9898 18th Apr 2009 8:40pm
philp
Just been outside and checked, all I have that looks like a bump stop are three “Dimples” in the upper sliding rail.
A 3mm Drill bit should sort these out,.
Can you post a picture of the part that is stopping you sliding the seat back further?
Don’t expect any miracles by raising the seat rails by using washers or Mudrails, the rear bulkhead will stop you getting the seat too much further back.
Phil
Post #9900 18th Apr 2009 10:08pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
If you use Mudrails you should get approx another 80mm of travel if you have a double cab Thumbs Up
Post #9901 18th Apr 2009 10:17pm
