![]() | Home > Puma (Tdci) > Is it possible for front seats to go further back? |
W11LLX Member Since: 05 Apr 2009 Location: derby Posts: 6 ![]() ![]() |
Is it possible for front seats to go further back on 110 xs?
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
have a look here:
http://www.mudstuff.co.uk/MUD_Seat_Rails.shtml |
thanks for that cob, I will get on to it, cheers mate 4 a quick response
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 ![]() ![]() ![]() |
Look also this topic from the past:
http://www.defender2.net/forum/post5794.html#5794 There are pics of DIY extensions rails. Janusz www.yahodeville.com |
Rob A Member Since: 06 Feb 2009 Location: Sao Paulo Posts: 29 ![]() ![]() ![]() |
Thanks Cobs for the mudstuff site, been looking for a simple solution like these rails for a while and there is lots of other cool bits and pieces there too. Well worth a look!!!
![]() Cheers Rob. 130 HCPU 2.4TDCi 110 300TDi |
philp Member Since: 21 Oct 2008 Location: surrey Posts: 22 ![]() ![]() |
I put a few washers on the seat bolts underneath the existing rail raising it 20mm or so.
You will need 4 slightly longer "grade 8.8" bolts which you can get from a decent hardware shop which along with the washers shouldn't cost more than £2 for the lot. That gets the seat back an inch or so,and saves a few quid. ![]() |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2449 ![]() ![]() ![]() |
I did the same! Puma 110" SW ............................................................. Earth first. Other planets later |
Think I'll try that too . . . . Thanks ![]() 110 300TDi |
Phil, finally got round to raising the seats, but could not push them back any further due to what looks like a built in "bump stop" inside the tubing. How did you get round this? All I can think of is putting two pieces of wood/metal under both sides of the assembly to bring it higher and then bolt onto that a few inches further back. It would have to be strong though. Any ideas? ![]() Thanks Rob 130 HCPU 2.4TDCi 110 300TDi |
Just been outside and checked, all I have that looks like a bump stop are three “Dimples” in the upper sliding rail.
A 3mm Drill bit should sort these out,. Can you post a picture of the part that is stopping you sliding the seat back further? Don’t expect any miracles by raising the seat rails by using washers or Mudrails, the rear bulkhead will stop you getting the seat too much further back. Phil |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
If you use Mudrails you should get approx another 80mm of travel if you have a double cab
