Home > Maintenance & Modifications > windscreen washers
Page 2 of 2 <12
JWL
Did mine on Monday, it was a fiddlejust made sure the pipes were on the washer jets when they were poked through, then put a washer and nut on the pipe so that they didn't dissappear when I was fiddling the nut on the thread. I kept the length of pipes from the washers to the "T" piece the same in the hope that it would keep an equal pressure throughout the pipework, probably not needed but it Whistle satisfied my OCD
Post #131414 14th Mar 2012 9:02pm
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
great little mod, mrs keeps tell me to stop cleaning the screen . Mr. Green
Post #131638 15th Mar 2012 6:43pm
AlpenAndes
Austria 2010 Defender 110 Puma 2.4 SW Belize Green
Tried to find if that mod also works on a TD4, but no result. Anyone tried it?
BR
Oskar
Post #131759 16th Mar 2012 5:49am
Should do.
I've got my bits in the garage ready to do this mod too. Thumbs Up
Post #131896 16th Mar 2012 5:39pm
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
OK what bits do I need, I'm sold! A T piece connector, some extra tube and an extra washer jet unit yeah? 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #131905 16th Mar 2012 6:23pm
BjornAgain
South Africa 1999 Defender 90 Td5 CSW Chawton White
I love finding posts where I have gone through the exact pain that someone else has! In the process of doing this Mod. Tolley, I have my flourescent tube hanging from the rearview mirror too! Rolling with laughter
Post #187051 21st Nov 2012 9:43pm
tolley
handy bit of kit Thumbs Up
Post #187055 21st Nov 2012 9:50pm
kzycnn
I did this mod but fitted 2 single washer jets to the outside and kept the original twin jet in the centre. On the drive it all worked great. In practice, at motorway speeds ( Question ) it was just a horrible little dribble that wouldn't even reach the screen Crying or Very sad
Now in bits again whilst I (i) test the centre washer jet with a replacement to see if it's just that losing all the pressure or (ii) replace the two outer washers with twin jet versions.
Getting a bit fed up with taking the dash to bits Smile
Tony
Post #187106 22nd Nov 2012 7:45am
geobloke
WarPig wrote:
Yep, done it to my 300tdi. Easy job to do.
I pulled out the dash top ashtray to expose the washer pipe connection with the washer nozzle. Undid the brass nut, pulled the pipe off, inserted a 'T' piece (available from aquatic shops and at BnQ in their hosepipe section).
Then using some similar pipe to existing, I fed a piece into the hole next to the wiper arm from the outside, and fished it through the dash and out of the ashtray hole, and connected to the 'T' piece. Repeated on the other wiper arm.
I tie clipped the pipe along each wiper arm and then connected it to a Peugeot spray arm - about £12 from Peugeot dealer, or cheaper from scrap yard.
The original washer nozzle remains, but unconnected. Though with a suitable '+' piece no doubt you could utilise that too?
This is what I did... http://www.reedx.net/landrover/mods/wipers/index.htm Good source of info REEDX.net.
The multiple Defender washers works really well too. Have a friend with 3 of them up front, goes through washer fluid like it was water... uhhh yeah anyway... Rolling Eyes[/url]
Post #187170 22nd Nov 2012 2:07pm
kzycnn
Are they all 'double' washers? Got my original disconnected at the moment and haven't yet tried a replacement. Was expecting to have to block this up and fit 2 twin jet washers in place of my current (after mod) single jets.
Tony
Post #187448 23rd Nov 2012 12:56pm
BjornAgain
What do you fill the hole with in the centre where the original washer jet was... do you just move the grommet from LHD arm? And does it fit onto the same hole?
Post #188355 25th Nov 2012 8:54pm
Page 2 of 2 <12
