Home > Maintenance & Modifications > windscreen washers |
Did mine on Monday, it was a fiddlejust made sure the pipes were on the washer jets when they were poked through, then put a washer and nut on the pipe so that they didn't dissappear when I was fiddling the nut on the thread. I kept the length of pipes from the washers to the "T" piece the same in the hope that it would keep an equal pressure throughout the pipework, probably not needed but it satisfied my OCD
14th Mar 2012 9:02pm |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1115 |
great little mod, mrs keeps tell me to stop cleaning the screen .
15th Mar 2012 6:43pm |
AlpenAndes Member Since: 20 May 2011 Location: Currently Chile Posts: 128 |
Tried to find if that mod also works on a TD4, but no result. Anyone tried it?
BR Oskar |
16th Mar 2012 5:49am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
Should do.
I've got my bits in the garage ready to do this mod too. |
16th Mar 2012 5:39pm |
BjornAgain Member Since: 29 Oct 2012 Location: Johannesburg, South Africa Posts: 22 |
I love finding posts where I have gone through the exact pain that someone else has! In the process of doing this Mod. Tolley, I have my flourescent tube hanging from the rearview mirror too! |
21st Nov 2012 9:43pm |
handy bit of kit
21st Nov 2012 9:50pm |
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 276 |
I did this mod but fitted 2 single washer jets to the outside and kept the original twin jet in the centre. On the drive it all worked great. In practice, at motorway speeds ( ) it was just a horrible little dribble that wouldn't even reach the screen
Now in bits again whilst I (i) test the centre washer jet with a replacement to see if it's just that losing all the pressure or (ii) replace the two outer washers with twin jet versions. Getting a bit fed up with taking the dash to bits Tony |
22nd Nov 2012 7:45am |
This is what I did... http://www.reedx.net/landrover/mods/wipers/index.htm Good source of info REEDX.net. The multiple Defender washers works really well too. Have a friend with 3 of them up front, goes through washer fluid like it was water... uhhh yeah anyway... [/url] |
22nd Nov 2012 2:07pm |
Are they all 'double' washers? Got my original disconnected at the moment and haven't yet tried a replacement. Was expecting to have to block this up and fit 2 twin jet washers in place of my current (after mod) single jets. Tony |
23rd Nov 2012 12:56pm |
What do you fill the hole with in the centre where the original washer jet was... do you just move the grommet from LHD arm? And does it fit onto the same hole?
25th Nov 2012 8:54pm |
