Home > Puma (Tdci) > Question For Weekend-What Cause The Truck To Drift Left? |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Maybe I didn't express myself well. Many years ago I had an old car that had { I think it was called McPherson Strut } front suspension that was basically the same as the Defender i.e.: Coil Spring with the Shock absorber in the centre. In order to change the shock you had to get it out and this was done by compressing the coil spring and disconnecting both spring and shock from the car and then sliding out shock. The Coil spring was compressed and then held in compression by metal [ clamps, normally 3 that, were slipped over the compressed coils . To my mind, if a similar system was used and a [ clamp was left on then that coil spring would be shorter - hence the vehicle would list to that side. I don't know how the shock was changed, only you would know that, nor if this method was used . It is just a theory, but if the vehicle was level before and is now listing, something has obviously happened to alter the suspension height. So even if you are mechanically challenged - careful visual examination of both front suspensions, measurements e.g.: Floor to wheel arch etc: should show which side is affected. Take some photos and display here? LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
13th Feb 2012 6:43am |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
To cure this problem on mine, I kept swopping the tyres around until the problem went. Now they are all labelled so I can put them back in the same place when I put the summer tyres back on.
Strangely fitting KM2 tyres also solved the problem. Merlin |
13th Feb 2012 7:12pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
sounds like steering damper clamp in wrong position or track rod problem. unlikely to be shocks or spacers
13th Feb 2012 10:06pm |
I accept what your saying BigMike but the poster stated the vehicle was now listing to the Left after the changes - not before LANDYWATCH
14th Feb 2012 12:00am |
Fatpig Member Since: 31 Oct 2011 Location: Chengdu Posts: 22 |
Thanks all for helpful inputs. Was just looking over pictures taken during the shock replacement. I did notice that front shock was replaced with removal of the turret, then by prefix the shock to the turret prior install. A hammer was used to set the new shock back into the turret.
Could something go wrong here? Also I noticed rubber bush goes on the end of the shock, if not fitted could it cause the tilt? |
14th Feb 2012 8:22am |
Hello great discovery today, no the truck is still on the open sea. But did manage look over workshop manual for Puma on the front suspension. Some enlightments here:
First of all, so whats holding the spring in place once the wheel has been lifted off the ground? The answer I found is the SHOCK. Secondly, what is the easiest way to lift the Defender or any car for an inch or so without spring and shock modifications? RUBBER BUSHINGS! With those two questions answered, here is the Hypothesis. If one of the rubber bushing inside the turret is left out on the left shock, would it result the tilt to the left and a sever left drift when driven? |
15th Feb 2012 4:10pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5744 |
No, i don't think it would, the ride height is dictated by the spring, not the damper.
Andy |
15th Feb 2012 8:59pm |
Then what would happen if the nut is loosen on top of the turret?
16th Feb 2012 6:09am |
Does your truck have anti-roll bars fitted? If so, and it was supported on the chassis at some point during the process, then it's possible that one of the links was accidentally inverted, which would make it sit awkwardly.
To be honest, I understand from other posts that the work was done for you, possibly by a forum sponsor? If so, should you not be asking them what they've done? Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
16th Feb 2012 8:20am |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 |
Nope, still drifts left. |
16th Feb 2012 8:46am |
Yes anti roll bar is installed, and I will check once it arrives.
16th Feb 2012 2:19pm |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
same topic on the disco forum, was cured by switching the wheels left/right.
Worth a try! Pom |
16th Feb 2012 5:09pm |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 |
Mine drifts left round roundabouts when i stamp on the loud pedal... and sometimes drifts to right round left handers too...
17th Feb 2012 7:33am |
