Home > Puma (Tdci) > Question For Weekend-What Cause The Truck To Drift Left?
Page 2 of 2 <12
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Maybe I didn't express myself well. Many years ago I had an old car that had { I think it was called McPherson Strut } front suspension that was basically the same as the Defender i.e.: Coil Spring with the Shock absorber in the centre. In order to change the shock you had to get it out and this was done by compressing the coil spring and disconnecting both spring and shock from the car and then sliding out shock. The Coil spring was compressed and then held in compression by metal [ clamps, normally 3 that, were slipped over the compressed coils . To my mind, if a similar system was used and a [ clamp was left on then that coil spring would be shorter - hence the vehicle would list to that side. I don't know how the shock was changed, only you would know that, nor if this method was used . It is just a theory, but if the vehicle was level before and is now listing, something has obviously happened to alter the suspension height. So even if you are mechanically challenged - careful visual examination of both front suspensions, measurements e.g.: Floor to wheel arch etc: should show which side is affected. Take some photos and display here? Bow down LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #123574 13th Feb 2012 6:43am
Fatpig
China 2012 Defender 110 Puma 2.2 XS CSW Santorini Black
ah! I see sorry for the misunderstanding. The front shock was change not by compressing the spring but to remove the top housing under the bonnet of the truck.
Sadly, the truck is on a ship to China right now. I will check and post pictures once it arrives.
Post #123610 13th Feb 2012 11:54am
Merlin
To cure this problem on mine, I kept swopping the tyres around until the problem went. Now they are all labelled so I can put them back in the same place when I put the summer tyres back on.
Strangely fitting KM2 tyres also solved the problem.
Merlin
Post #123700 13th Feb 2012 7:12pm
BigMike
sounds like steering damper clamp in wrong position or track rod problem. unlikely to be shocks or spacers
Post #123778 13th Feb 2012 10:06pm
WelshGas
I accept what your saying BigMike but the poster stated the vehicle was now listing to the Left after the changes - not before Wink Wink LANDYWATCH
Post #123798 14th Feb 2012 12:00am
Fatpig
Thanks all for helpful inputs. Was just looking over pictures taken during the shock replacement. I did notice that front shock was replaced with removal of the turret, then by prefix the shock to the turret prior install. A hammer was used to set the new shock back into the turret.
Could something go wrong here? Also I noticed rubber bush goes on the end of the shock, if not fitted could it cause the tilt?
Post #123823 14th Feb 2012 8:22am
Fatpig
Hello great discovery today, no the truck is still on the open sea. But did manage look over workshop manual for Puma on the front suspension. Some enlightments here:
First of all, so whats holding the spring in place once the wheel has been lifted off the ground? The answer I found is the SHOCK.
Secondly, what is the easiest way to lift the Defender or any car for an inch or so without spring and shock modifications? RUBBER BUSHINGS!
With those two questions answered, here is the Hypothesis. If one of the rubber bushing inside the turret is left out on the left shock, would it result the tilt to the left and a sever left drift when driven? Whistle
Post #124148 15th Feb 2012 4:10pm
landy andy
No, i don't think it would, the ride height is dictated by the spring, not the damper.
Andy
Post #124232 15th Feb 2012 8:59pm
Fatpig
Then what would happen if the nut is loosen on top of the turret?
Post #124345 16th Feb 2012 6:09am
Does your truck have anti-roll bars fitted? If so, and it was supported on the chassis at some point during the process, then it's possible that one of the links was accidentally inverted, which would make it sit awkwardly.
To be honest, I understand from other posts that the work was done for you, possibly by a forum sponsor? If so, should you not be asking them what they've done? Darren
Post #124374 16th Feb 2012 8:20am
22900013A
kingofthesparks wrote:
22900013A wrote:
Sadly mine has drifted left from new, and its totally standard...
But if you take it abroad i bet it drifts to the right Whistle , camber sensitive Thumbs Up
Nope, still drifts left.
Post #124379 16th Feb 2012 8:46am
Fatpig
Yes anti roll bar is installed, and I will check once it arrives.
Post #124441 16th Feb 2012 2:19pm
pom
same topic on the disco forum, was cured by switching the wheels left/right.
Worth a try!
Pom
Post #124468 16th Feb 2012 5:09pm
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
Mine drifts left round roundabouts when i stamp on the loud pedal... and sometimes drifts to right round left handers too... Very Happy
Post #124649 17th Feb 2012 7:33am
Page 2 of 2 <12
