Home > Technical > Screen washer? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20376 |
Washer nozzle I would call it. Try a needle or pin in the nozzle and you might find that it'll free the debris in there. You can also fine tune the direction of the jet like this too. Which one is it that you've got probalems with front or rear?
11th Feb 2012 3:30pm |
CRJ Member Since: 12 Mar 2011 Location: Sealand - Denmark Posts: 253 |
Washer nozzle - thank you I did try with a needle and it is the one in front. As it has turned loose i was thinking about taking it of and trying compressed air in the tube.
CRJ 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
11th Feb 2012 3:38pm |
That could work I guess. It'll more likely free it in the direction it came into the nozzle than through the direction it should have if you understand what I mean. It's difficult to explain through this. Good luck |
11th Feb 2012 3:49pm |
ok - but how do I take of the entire nozzle - it is lose and turning but I cannot take it of. Hope it is not mounted from inside
11th Feb 2012 3:58pm |
I'm not sure myself someone else better informed should give you an answer soon. I have a horrible suspition for to that it will be |
11th Feb 2012 4:02pm |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
They just pull off and tap back on. But as they are two piece if it is the "through body" part that is turning you will have to remove the dash. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
11th Feb 2012 4:25pm |
Good new then |
11th Feb 2012 4:26pm |
Aaarggh - I guess I have to remove the dash then - or apply some black sealant and hold it in place.. as it is the "body part" that is turning.
Regards CRj 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
11th Feb 2012 4:38pm |
I may be wrong but the Puma has the benefit over the TD5 in that the centre of the console comes out and you may get a spanner onto the 11mm brass nut?? I had to take the dash out of my TD5 and it was a lesson in screwdriver usage. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
11th Feb 2012 7:16pm |
I will have a look tomorrow - getting tired of hanging out of the drivers side window applying washing fluid to the windscreen. It is quite cold in the morning
11th Feb 2012 9:05pm |
Martyn Member Since: 10 Feb 2011 Location: Stourbridge, West Midlands Posts: 151 |
Did you conclude how to get to the brass nut behind the dash holding the twin washer jets in place? I need to replace mine as they squirt in every direction but on the window and for the sake of £6....
Used to be able to pop the tray out of the dash in the old ones and have access that way but not applicable to the new Puma dash. Stereo surround maybe? Let me know! |
14th Feb 2012 7:38pm |
[quote="Martyn"] I need to replace mine as they squirt in every direction but on the window and for the sake of £6....
I'm sure you probably already have but have you adjusted the direction of the nozzles with a pin or similar? |
14th Feb 2012 8:15pm |
Sure have. Direction of brass jet bares no resemblance to the direction the screen wash squirts
14th Feb 2012 11:03pm |
robpenrose Member Since: 15 Jan 2011 Location: Hampshire or Cornwall Posts: 338 |
You can take the Winscreen vents off and the ash tray out of the Td5 to gain access to it.
Cant you do the same on a Puma? Current:D4 HSE Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
15th Feb 2012 3:56pm |
