Home > Technical > Screen washer?
Page 2 of 2 <12
Martyn
United Kingdom 2014 Defender 90 Puma 2.2 PU Keswick Green
Regrettably not. Vents not in the 07+ Puma and the ashtray is moulded in. Bought the part today for £6 from the stealers. Looks like the threaded tube is either glued or fixed in with a pressure fixing as I can't yank the two apart and I'm a big chap lol.
At the weekend, I'll have a look at what access is offered by removing te centre console fascia. I don't have the 2 keys needed to slide the radio out and I certainly don't wanna be removing sections of the dash. Confidence in doing that = zero Sad
Post #124182 15th Feb 2012 6:30pm
VeeTee
Netherlands
My screen washer nozzles were also blocked. I disconnected the tubing at the reservoir and then blew some pressurized air through the nozzles (in the direction from nozzle to reservoir), this removed the blocking. Cheers, Vincent
MySite
Post #124188 15th Feb 2012 7:00pm
RED-DOT
My Defender has been parked up since December and have went out today to run the engine and top up the washers and the ice has cracked the through body L shaped pipe. Does anyone have the LR procedure for changing the complete part??? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #124478 16th Feb 2012 5:40pm
Page 2 of 2 <12
