Home > Technical > Squeaking clutch pedal
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
Every time I press the clutch in it squeaks any ideas and I have done a search already Very Happy
Post #117943 23rd Jan 2012 9:29pm
CR
Ireland 2011 Defender 110 Puma 2.4 CSW Santorini Black
Mine was doing it, brought it back to the dealer to oil at spring
Squeak gone
Post #117948 23rd Jan 2012 9:36pm
Scallops
Australia
I had this happen after 50 000km - LR dealer would lubricate it, it would fix it for several months but come back. Eventually they replaced the entire pedal assembly....that was the only fix that lasted....
Post #117951 23rd Jan 2012 9:43pm
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Well if you are into DIY, you can open up the bonet. There is housing attached to the bulkhead that holds the clutch pedal, on top of the housing are 6 screws, remove them, then you can see the top of the pedal. Put a few drops of oil on the bit that squeaks and bingo - no more annoying noise... well not from the clutch anyway!
Post #118013 24th Jan 2012 6:57am
What?
Proposterous replies!
You'll be getting rid of wet carpets and rattles next Crying or Very sad
Mr. Green
Post #118020 24th Jan 2012 7:58am
JWL
Mine has it's own cure..............every so often the master cylinder leaks, first shown by a drip of fluid on the top of your boot and then a fluid mark on the mat. If the mark is added to over 2 days then I need to top up the reservoir otherwis it just dries up and you leave it, very much"If it 'aint broke then don't fix it". My 90 used to drive me mad with its squeak and had to be manually lubed every month Rolling Eyes
Post #118071 24th Jan 2012 11:37am
mick
Tried that it's no different.
Post #118093 24th Jan 2012 1:23pm
Happyoldgit
My current Puma pedal has suffered from a squeaky pedal every now and again especially before the spring decided to ping off the pedal some months ago. There is a plastic sleeve in the pedal in which the spring sits, the last time it started to squeak I just put a drop of thick oil on it and it's been fine ever since but it is one of the things on my warranty list the next time it goes in for a service Steve.
http://forums.lr4x4.com
Post #118148 24th Jan 2012 4:27pm
18stone
England 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Had exactly the same problem. Whatever I lubricated it with it would still squeak. At the 12k service they said they couldn't get it to do it. Once I'd told them 'rubbish, it does it EVERY time', they went away and fixed it. They just lubricated it but I've no idea what with. That was 1000+ miles ago and it's fine still. D300 HSE 110
Post #118924 27th Jan 2012 2:32pm
rossy
I bet they used lithium spray grease. That stuff gets everywhere and stays there. All dealers use it to shut people up and make them go away (a Mitsubishi main dealer mechanic told me that !)
Post #119057 27th Jan 2012 7:24pm
