Home > Technical > Squeaking clutch pedal |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
Every time I press the clutch in it squeaks any ideas and I have done a search already
23rd Jan 2012 9:29pm |
CR Member Since: 28 Jan 2010 Location: Ireland Posts: 947 |
Mine was doing it, brought it back to the dealer to oil at spring
Squeak gone |
23rd Jan 2012 9:36pm |
Scallops Member Since: 15 Aug 2007 Location: Brisbane Australia Posts: 89 |
I had this happen after 50 000km - LR dealer would lubricate it, it would fix it for several months but come back. Eventually they replaced the entire pedal assembly....that was the only fix that lasted....
23rd Jan 2012 9:43pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10381 |
What?
Proposterous replies! You'll be getting rid of wet carpets and rattles next |
24th Jan 2012 7:58am |
Mine has it's own cure..............every so often the master cylinder leaks, first shown by a drip of fluid on the top of your boot and then a fluid mark on the mat. If the mark is added to over 2 days then I need to top up the reservoir otherwis it just dries up and you leave it, very much"If it 'aint broke then don't fix it". My 90 used to drive me mad with its squeak and had to be manually lubed every month
24th Jan 2012 11:37am |
Tried that it's no different. |
24th Jan 2012 1:23pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
My current Puma pedal has suffered from a squeaky pedal every now and again especially before the spring decided to ping off the pedal some months ago. There is a plastic sleeve in the pedal in which the spring sits, the last time it started to squeak I just put a drop of thick oil on it and it's been fine ever since but it is one of the things on my warranty list the next time it goes in for a service Steve.
24th Jan 2012 4:27pm |
18stone Member Since: 16 Dec 2010 Location: Mid Essex Posts: 137 |
Had exactly the same problem. Whatever I lubricated it with it would still squeak. At the 12k service they said they couldn't get it to do it. Once I'd told them 'rubbish, it does it EVERY time', they went away and fixed it. They just lubricated it but I've no idea what with. That was 1000+ miles ago and it's fine still. D300 HSE 110
27th Jan 2012 2:32pm |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
I bet they used lithium spray grease. That stuff gets everywhere and stays there. All dealers use it to shut people up and make them go away (a Mitsubishi main dealer mechanic told me that !)
27th Jan 2012 7:24pm |
