Home > Maintenance & Modifications > New reg plate LED ight
Page 4 of 5 <12345>
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
Post #118016 24th Jan 2012 7:25am
ericvv
Seems the below LED unit from Perei would be a direct replacement for the standard bulb fitted number plate units on our Defenders.
Perei are the manufacturers of other lights on certain Defender models and the quality of those is outstanding. So if the below unit would indeed be a direct replacement, probably our best bet, beating anything Chinese by arms length.
Can any of the site sponsors confirm that this is a direct replacement, that it is indeed superior quality, and are they already offering this unit or can they do so? I checked a few sponsor websites and did not find them.
The unit type is Perei NPL2BLED. You can click the datasheet and ECE certificates link, and can see all measurements there which seem to be identical to the standard bulb type units.
http://www.perei.co.uk/products?page=shop....gory_id=27 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #181845 4th Nov 2012 6:51am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Well I did it and bought one of the perei ones direct replacement just have to modify the the cable hole entry through the spacing block solder the wires and there we go fully 'E' marked led number plate lamp hopefully it will last longer than the BoB's one I had ! And it cost 10.80 plus vat!
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #184489 12th Nov 2012 10:00pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Will
Hi fella where did you get it from ? There site is got a buy it section that I can see
Cheers It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #184490 12th Nov 2012 10:05pm
derbywill
I got it from a local Hgv factors as these buy lamps from perei it took a while to come as I ordered it on there stock order
Will 2005 90 XS
1968 88” 2A 200tdi
2002 110 Hardtop
Post #184491 12th Nov 2012 10:09pm
mobilecentre
We will be around 12.99 + Delivery + VAT for those that cannot wait.
If you have a week or so to spare then we should get some better pricing for Def2 members Thumbs Up
Post #184681 13th Nov 2012 4:06pm
dgardel
Italy
I'm here!!! Mr. Green Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #184685 13th Nov 2012 4:11pm
mobilecentre
You are now TOP of the list - do not tell Eric Thumbs Up
Post #184694 13th Nov 2012 4:48pm
ericvv
I'm in too. No problem to wait another week, or a few weeks... Thumbs Up
Daniele, don't really understand you. You already have replaced your number plate lamp by a LED version Question ..... but of course, not the Perei version that is Wink You never actually own a Defender. You merely look after it for the next generation.
Post #184698 13th Nov 2012 4:50pm
ericvv
Tim, let's stay productive,.....just keep looking for that first class LED replacement for our aux high beam lamps... Whistle You never actually own a Defender. You merely look after it for the next generation.
Post #184700 13th Nov 2012 4:54pm
mobilecentre
I have ordered LH & RH SVX driving lamps which will be here tomorrow hopefully. We will then look at how to mount a 90mm lamp or maybe even make a new one!!
Post #184701 13th Nov 2012 4:55pm
ericvv
Good, my Defender has to go back to the dealer in a few weeks time and they will have to dismantle the entire front to repair/replace one of the headlamp electric levelling units which stopped working. So they can then also install those LED aux lamps provided they pass your tests....
One question about those, will they be the pencil beam type or the driving light beam type? By that I mean the driving beam type should be a bit more spread out light than the first mentioned. I think that driving beam would be preferable, because I believe the Speaker high beam is fairly pencil type, yes? Not really 100% sure abt that as they light up together with the H7 aux lamps now, but I have that impression. You never actually own a Defender. You merely look after it for the next generation.
Post #184707 13th Nov 2012 5:06pm
mobilecentre
Once we figure the mounting out then we can look at the optics / beam pattern.
Post #184710 13th Nov 2012 5:19pm
ericvv
Post #184712 13th Nov 2012 5:23pm
dgardel
Italy
Tim have you received my email? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #184717 13th Nov 2012 5:34pm
Page 4 of 5 <12345>
