Home > Maintenance & Modifications > New reg plate LED ight
Page 3 of 5 <12345>
XS Pete
I'll pop some photos up when I fit them, if they don't work well, I'll get them replaced. Thumbs Up
bp
Post #116682 19th Jan 2012 8:24am
MartinK
A good place to look for alternative bulbs is www.autobulbsdirect.co.uk
The bulbs is type 233 or equivalent
These are the rear number plate bulbs recommended for a Defender:
http://www.autobulbsdirect.co.uk/233-T4W/?...p;end=rear Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #116693 19th Jan 2012 9:27am
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
bp - The other thing that dawned on me this morning when I went out to the car was that assuming you can actually fit them (those are quite long and the enclosure is quite tight on space), the actual position of how the bulb sits, is governed by the two metal pins on the base.
To fit them, you basically put them in and give them a quarter turn, and that engages the two metal pins on the lamp base with a pair of detents in the bulb holder. This means that the lamp can only be fitted in two positions rotated 180 degrees apart, governed by the pins.
On your lamps, if the relationship between the position of the LED board and the position of the pins isn't 'favourable' for our installation, i.e. maybe front to back, you may get very little light output at all.
Reading that back, it all sounds a bit anal, but you'll see what I mean when you come to fit them.
Pete
Post #116694 19th Jan 2012 9:35am
Martin
Site Admin
DISCO3 site sponsor www.hids4u.co.uk do a wide range of quality LEDs - worth a look if you want to be sure they're not going to fail after a few months.
You can check their feedback on DISCO3 if you like Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #116699 19th Jan 2012 10:12am
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
bpman wrote:
I ordered 2 of these today, will post up photo of fitting when they arrive
http://www.ultraleds.co.uk/ba9233-anti-bul...brqlm364k4
I fitted these in my number plate light a few months ago, bit tight, but works a treat pal.
Post #116704 19th Jan 2012 10:33am
thanks for the feed back Paul, I had the dispatched email from ultraleds today, so should arrive tomorrow .. Thumbs Up
Post #116847 19th Jan 2012 8:05pm
here we are ...
Post #117108 20th Jan 2012 7:31pm
XS Pete
That looks ok doesn't it Thumbs Up
Post #117458 22nd Jan 2012 10:14am
landy andy
Personally think they look better if you leave the spacer out, from in between light and the body Whistle
Andy
Post #117460 22nd Jan 2012 10:29am
dgardel
Italy
Fitted!!!!
Sealed well with black silicon the lamp internal junctions and fixed the lamp base and the plinth with rivnut, this is the results:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #117528 22nd Jan 2012 5:39pm
dgardel
Italy
IID Pro MV License
Post #117665 22nd Jan 2012 11:04pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Re: Fitted!!!!
Is it a straight swap ? Remove the old one and fit the new one ? Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #117683 22nd Jan 2012 11:48pm
dgardel
Italy
Re: Fitted!!!!
yes Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #117687 22nd Jan 2012 11:56pm
look good daniele, it will be interesting to see how long they last. maybe there was a bad batch previously ?
Post #117871 23rd Jan 2012 8:01pm
dgardel
Italy
we will see................. Mr. Green Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #117893 23rd Jan 2012 8:34pm
Page 3 of 5 <12345>
