![]() | Home > Maintenance & Modifications > New reg plate LED ight |
Seems the below LED unit from Perei would be a direct replacement for the standard bulb fitted number plate units on our Defenders.
Perei are the manufacturers of other lights on certain Defender models and the quality of those is outstanding. So if the below unit would indeed be a direct replacement, probably our best bet, beating anything Chinese by arms length. Can any of the site sponsors confirm that this is a direct replacement, that it is indeed superior quality, and are they already offering this unit or can they do so? I checked a few sponsor websites and did not find them. The unit type is Perei NPL2BLED. You can click the datasheet and ECE certificates link, and can see all measurements there which seem to be identical to the standard bulb type units. http://www.perei.co.uk/products?page=shop....gory_id=27 You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 560 ![]() ![]() ![]() |
Well I did it and bought one of the perei ones direct replacement just have to modify the the cable hole entry through the spacing block solder the wires and there we go fully 'E' marked led number plate lamp hopefully it will last longer than the BoB's one I had ! And it cost 10.80 plus vat!
Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
I got it from a local Hgv factors as these buy lamps from perei it took a while to come as I ordered it on there stock order
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 ![]() ![]() |
We will be around 12.99 + Delivery + VAT for those that cannot wait.
If you have a week or so to spare then we should get some better pricing for Def2 members ![]() |
I'm here!!! ![]() ![]() ![]() IID Pro MV License |
You are now TOP of the list - do not tell Eric ![]() Last edited by mobilecentre on 13th Nov 2012 4:51pm. Edited 1 time in total |
I'm in too. No problem to wait another week, or a few weeks...
![]() Daniele, don't really understand you. You already have replaced your number plate lamp by a LED version ![]() ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Tim, let's stay productive,.....just keep looking for that first class LED replacement for our aux high beam lamps... ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
I have ordered LH & RH SVX driving lamps which will be here tomorrow hopefully. We will then look at how to mount a 90mm lamp or maybe even make a new one!! |
Good, my Defender has to go back to the dealer in a few weeks time and they will have to dismantle the entire front to repair/replace one of the headlamp electric levelling units which stopped working. So they can then also install those LED aux lamps provided they pass your tests.... One question about those, will they be the pencil beam type or the driving light beam type? By that I mean the driving beam type should be a bit more spread out light than the first mentioned. I think that driving beam would be preferable, because I believe the Speaker high beam is fairly pencil type, yes? Not really 100% sure abt that as they light up together with the H7 aux lamps now, but I have that impression. You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Once we figure the mounting out then we can look at the optics / beam pattern.
Gotcha. Waiting patiently..... You never actually own a Defender. You merely look after it for the next generation.
Tim have you received my email? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
