Home > Maintenance & Modifications > Heated mirror from heated screen |
Morning all
It's minus 12 outside this morning and I've changed my mind... I really would like a heated wing mirror! As I have a long large purple wire easily accessible for the heated windscreen, can anyone give a reason why I shouldn't take a spur off it and use it for the mirror too? Using the same heater switch would be perfect. The screen uses a 30A fuse and the mirror I'm looking at is rated 15A max. Guess I could uprate the fuse a bit if neccesary... Otherwise I probably won't bother (lazy ) Cheers Matt p.s. yes, I've searched (...a bit) Have a terrific day all Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
16th Jan 2012 9:24am |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1114 |
sorry to jump on your tread,is it much of a job to fit a heated screen and mirrors to td5 which has none
thanks |
16th Jan 2012 11:11am |
Great, thanks Do you stick with the 30A fuse? Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
16th Jan 2012 11:17am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Yep no issues at all
16th Jan 2012 11:19am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17210 |
A little o/t but related to this question:- I am planning to fit a heated screen (plus probably heated mirrors) and was also thinking of connecting theme to the same switch (I can't use the HRW circuit since I have already used that for something else).
With the standard heated screen wiring, I know that there is a timer to switch the element off after a certain period, but can it also be switched off manually before the timeout, by means of a second switch activation? or is it always on until the timer times out? Thanks. |
16th Jan 2012 11:43am |
Yes, by pressing the button again. Mind you, the timer is only about 10 minutes, IIRC. Darren
16th Jan 2012 11:50am |
Update - heated mirror is now fitted and works a treat
Gets pretty warm very quickly though - hope it lasts Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
23rd Jan 2012 3:28pm |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
Right I fitted a heated wing mirror kit over Christmas but several attempts to get it working have all failed
I did have one working and found I has a loose wire so connected it and just caused the working pad to stop Russell 2011MY 110 XS USW Black |
23rd Jan 2012 3:51pm |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 |
As well as buying the heated mirror elements, am I right in thinking you can also buy heated mirrors as a complete unit?
23rd Jan 2012 4:49pm |
Where you routing the cable? photos?? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
23rd Jan 2012 5:06pm |
I bought a complete mirror unit (not the bracket) and there is a cable (about 3' long) sticking out of it with 2 wires. Just mount the thing on the bracket ball. Whole unit was about 30 quid.
To route the cable, I drilled a hole through to the inside, just above where the door hinge fixes to the frame. There is just enough room here (you can see it's a bit "deeper" on the inside where the door seal bends). I angled the hole slightly upwards to encourage water to come out instead of in. The frame has two skins, so to prevent chafing, I made a sheath out of a bigger piece of rubber cable to pass through the frame (slanting slightly down) and sticking out a bit both sides. Everything was glued in place with polyurethane glue and sealed up with Sikaflex (brilliant stuff ) As I have a heated front windscreen, the rest was easy. I just soldered the brown wire to the windscreen heater connector and drilled a small hole just above the top "fake hinge" bolt and used a self-tapping screw to fix the blue wire to earth. The mirror just works exactly the same as the windscreen Photos tomorrow if anyone is still awake... p.s. Still trying to convince the wife to go back to Caorle this year Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
23rd Jan 2012 7:26pm |
Thanks, where did you buy the mirrors from? Photos would be useful for me please |
23rd Jan 2012 7:42pm |
<thank you Ze, please take a photo " I drilled a hole through to the inside, just above where the door hinge fixes to the frame" Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
23rd Jan 2012 7:48pm |
did you put the mirrors in upside down ? |
23rd Jan 2012 7:59pm |
