Home > Puma (Tdci) > Engine lift bracket.. GRRRRRR
Page 3 of 4 <1234>
ericvv wrote:
Same with me. Red engine bracket is there. Nothing comes closer than 3 or 4 cm, so presume no need to remove it. Who knows, one day in the future it might serve its purpose. Whistle Hope not of course...
Ericvv I think ours being LHD are slightly different, I also checked mine and can't see any problem. Thumbs Up
Post #116085 17th Jan 2012 7:29am
Zagato
Had a look under the bonnet of the 2.2 yesterday Shocked It's a lot busier in there Shocked
The silly rear door handle with holes in it made me laugh - somebody must have been really bored one afternoon Rolling Eyes
Post #116090 17th Jan 2012 7:43am
cinstone
England 2015 Defender 90 Puma 2.2 XS CSW Keswick Green
Two bolts??? Mine has just the one, now anyway Rolling Eyes.
Chris. http://shropshirelandrovers.freeforums.org
2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW.
Previous LR's: Michael, my 2008 Defender 90 XS SW.
Machinas oportet intrare non capsicum annuum faveo
Post #116100 17th Jan 2012 8:50am
Zagato
Embarassed One has already fallen out! Shocked
Post #116183 17th Jan 2012 2:15pm
ZeDefender
Mine doesn't seem to have one - is it somewhere hidden for us LHDs? Tell someone you love them today because life is short.
Post #116188 17th Jan 2012 2:29pm
ericvv
Not hidden at all. When you watch the engine from the driver side of the LH drive vehicle. it is a big bright red bracket located close to the bulkhead. If it is there, can't miss it. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #116263 17th Jan 2012 7:25pm
Zagato
Mine didn't have one either they stopped putting them in on later models Thumbs Up
Post #116312 17th Jan 2012 9:11pm
Bearcat
Ireland
I just put pipe insulator around the pipe that rubs off the red hoist mount. My puma has 63k miles and pipe wasn't chaffed. Current...07 90 Puma commercial
Porsche 930 1988 (laid up)
Previous Td5 90 & V8 90
Post #116388 18th Jan 2012 6:24am
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Re: Engine lift bracket.. GRRRRRR
Shax wrote:
Just a quick reminder to all owners get the red engine lifting bracket removed... Mine still has it, and now has a bloody great hole in the heater feed pipe where it has been rubbed away..
Now I know why it recently lost 4 litres of water!
I feel a(nother!) warranty claim coming on...
Took my 90 to Stratstones in Burnham last week.. The techie had a look see, and said, "Yup, it's f*$ked.." Took the keys, couriered a new hose in, swapped out the dud, took off the bracket and refilled the coolant.. All in about 4 hours.. Very Happy
And he also found leaking swivel seals, agreed to replace the headlight surrounds, front mudflaps and rear window... It went in today for the bits under warranty.. Pick it up in the morning... I'll shout loud if any work aint been done!!! ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #117910 23rd Jan 2012 8:08pm
Projectblue
Just to say thanks for the tip. Checking the fluids in preperation for prospective weekends snow, I decided to remove the bracket. Despite tightening the bolts 2 months ago before I read this thread, one had worked loose enough that 2 secs finger tip work removed it. Needless to say I took the Censored off this time!
This should be a bloomin recall notice surely?
Post #120639 2nd Feb 2012 4:20pm
PK1
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Red Bracket falls off!
Thud Heard a noise - looked under the bonnet and found a red bracket. New to all this so investigated this forum only to find out the recommendation is to remove bracket...........so being keen went straight out to investigate further. Touched red bracket and it fell off!!! OMG how lucky I investigated - Thanks peeps!! Bow down
Post #177188 19th Oct 2012 5:20pm
Good job you did then or it could have been in someone's windscreen behind if it fell onto the road. Shocked Play Stupid Games, Win Stupid Prizes.
Big Brother is Watching.
Post #177194 19th Oct 2012 5:45pm
who legally would be responsible for that ? the owner or land rover ?
Post #177197 19th Oct 2012 5:47pm
Is this on a 2.2 - where should I be I looking?
Post #401948 25th Feb 2015 9:52am
ericvv
^^ Puma 2.2 rear door handle. It is the environmental guys in Solihull's solution to Defender weight saving. The Puma 2.4 has a solid door handle without holes.
But then those same Solihull environmentalists witth the Puma 2.2 added a rubber lead to the fuel cap. So by this they erased 50% of those weight savings again. Rolling Eyes
eric You never actually own a Defender. You merely look after it for the next generation.
Post #401954 25th Feb 2015 10:13am
Page 3 of 4 <1234>
