Home > Maintenance & Modifications > Door Seals
Page 2 of 3 <123>
robpenrose
bpman wrote:
I agree, use genuine.
One thing you could try .. I used to get some water in on my td5, passenger side - it seemed to be in the curve of the door where the rubber bends, I put some grease on the rubber and that solved it .. Thumbs Up
The area you mention is exactly where mine has deformed and looks very different to the drivers side. I think it needs replacing regardless if it's the source of the leak.
Looks like I will have to bite the bullet and go genuine.
Thanks for the update on the Discount from the Disco 3 guys, I will look into that.
Once I have replaced that, I will properly look for the water ingress. Current:D4 HSE
Gone: BMW Z4MC
Gone: Defender TD5 90 CSW
Previous: Discovery TD5 ES (Gone)
Post #112592 5th Jan 2012 8:42pm
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Hi Bob,
I have the Nakatanenga seals on my front doors, and whilst they definitely reduce dust ingress dramatically, and even reduce wind noise, they don't (in my experience, but I didn't have leaky doors before fitting them) have much effect on water ingress (nor, AFAIK, are they designed to).
To be fair, the only leaks I had in my 110 were coming from the screen seals (both from the windscreen rubber, foam strip below windscreen and gasket behind screen 'block'.
I cured all of these leaks with a good application of Captain Tolley's Creeping Crack Cure, which is superb stuff (originally designed for boats). It has very high viscosity, which helps it to 'seek out leaks/gaps;. Before you all snigger, do a Google search!
I now have a perfectly dry interior in my 110......for now anyway!
bob neville wrote:
Still trying to find somebody who has fitted the Nak seals. Expensive but if they stop the leaks and fit better than the OEM ones then I would fit them.
Bob
2010 110 XS USW (the slow one)
1960 Alfa Romeo Giulietta SZ (the fast one)
2005 Ducati ST3
1954 Sunbeam S8
Post #112619 5th Jan 2012 9:35pm
bob neville
Thanks James Thumbs Up
Bob
Post #112625 5th Jan 2012 9:41pm
ZeDefender
Did you remove the foam rubber strip under the windscreen first or just treat the foam rubber itself?
AND how much would I need for the windscreen surround and the foam? I have a choice between 60 ml and 250 ml and postage from the UK ain't cheap Shocked
Matt Tell someone you love them today because life is short.
Post #112634 5th Jan 2012 9:49pm
Snowbeast17
Scotland 2011 Defender 110 Puma 2.4 USW Stornoway Grey
Hi guys, I still have this water leak dripping on to the brake peddle and last week thought I had worked out where it was comming in. I thought it was through the rubber foam under the windscreen. You can see about 1cm of it at the side of the dash and it was soaking wet. So I neatly siliconed it ( black) thinking this was going to fix it.
Well it didn't! So now I'm sure it's coming through the windscreen seal and running down from there.
It going to the dealer to get the windscreen sealed so hopefully that will be it sorted. RRS tdv8 08
Disco 3 HSE 57
Defender 90 xs 06
All gone
Post #112652 5th Jan 2012 10:15pm
szracer
I merely squirted a small 'bead' of Captain Tolley's all along the foam strip, top and bottom, around the windscreen blocks, and also around the inner bottom corners of the windscreen rubber.
It's very runny stuff, and you only need a very small amount, as it 'finds its way' to the leaks by capillary action. If you put too much on, you end up having to wipe off the excess. It does dry clear, though. 60ml should do you. I've used only a fraction of the bottle I bought.
Matt
2005 Ducati ST3
1954 Sunbeam S8
Post #112666 5th Jan 2012 10:24pm
Retroanaconda
Matt
My concern with this is that the instructions for this stuff say it doesn't work in wet conditions. The inside of my windscreen seal is quite wet (god-damn new seal leaking, can't believe it!), so I doubt it would work in my case.
For what it's worth I have a new windscreen seal, new foam strip, new seals under the screen clamps, new door seals. Still ******* leaks!
Post #112682 5th Jan 2012 10:39pm
szracer
Actually, it doesn't say it doesn't work in wet conditions, but it does say that the area should be as dry as possible.
In my case, I did it in the height of Summer.
However, what about plugging a small fan heater to an extension cable and leave it sitting on the front seat, facing the windscreen. After an hour or so, the seal should have dried out?
Matt
2005 Ducati ST3
1954 Sunbeam S8
Post #112940 6th Jan 2012 6:05pm
bmc054
2002 Defender 90 Td5 HT Tonga Green
Seal
I replaced the seal between screen and bulkhead but found one wasnt thick enough to stop the leak so I fitted two one on top of the other and pulled the roof down with a ratchet strap each side to compress the seals while I put the bolts back through
Hope this helps
Bob
Post #112986 6th Jan 2012 7:36pm
bob neville
Bob
NAK seals? Care to elaborate?
These Thumbs Up
http://nakatanenga-tours.de/shop/article_T...DDLL-VR%26
2013 Defender 90 CSW - sold
Post #113063 6th Jan 2012 10:08pm
Tazz
Well I fitted aftermarket seals from Craddocks (TD5 110) and have no complaints.
Post #115324 14th Jan 2012 2:17pm
Grockle
check the washer pipes for the rear window washer, water can track through the bulk head on the pipes,remove the speaker for access 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #115348 14th Jan 2012 5:25pm
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Well I just fitted a set of front door rubber seals from Paddocks (which are actually Britpart) and now I have to slam the doors so hard to shut them I feels like I am going to break something and the Censored doors leak.
Where can I get a genuine set from?
Post #220191 18th Mar 2013 2:02pm
ZeDefender
I've paid for "OEM" and got "the other one" from Paddocks before Sad Tell someone you love them today because life is short.
Post #220197 18th Mar 2013 2:56pm
sewin elwy
Wales 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
footwell water leak
If the water is pooling in the foot well and or running down the pedel it will be getting in at the foam seal between the bulkhead and the pedel box.
Its the same as all the other foam seals and they have a very short effective life!
Silkaflex is great stuff and works really well. Use it on this seal and on the seals for the screen, roof at the front and the tub. You can get a really professional finish without much effort.
Leave the original seals in place as you are then only surface filling. If you need to dismantle in the future a simple shallow central cut is all that's required to release them.
On areas like the tub use masking tape either side of the joint, don't over-fill and use a plastic spatula to remove the excess. then the wet finger technique to finish. It will give you a factory finish I promise!
If anyone wants a look at mine and are local ( I'm just off the A55 in north wales) you're welcome!
Martin.
Post #317765 21st Mar 2014 11:51am
Page 2 of 3 <123>
