Home > Puma (Tdci) > Poor performance |
Please keep is updated with the results. Brian |
16th Jan 2012 4:40pm |
CRJ Member Since: 12 Mar 2011 Location: Sealand - Denmark Posts: 253 |
Short update - did 150 km today without any problems - pulls great from 1500 rpm. will give it a few more days and then see what fault codes will show.
Regards CRJ 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
17th Jan 2012 10:22pm |
Still no problems - gone from about 500 km on a tank to about 600 - even pulled a trailer some of the way.
Fault codes now P1402 P0234 P0100 P0623 Did think about cleaning the ECU connections once more - any recommendations on how to? Regards Christian 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
20th Jan 2012 10:03pm |
Torque is also back - clutch is gone today
What is the easiest way to remove gearbox - seat base out - or from underneath ? Regards Christian 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
21st Jan 2012 8:03am |
Regarding clutch change - I ordered a new one today - was told that normally one does´t change the release bearing as it is part of the slavecylinder - I never changed a clutch without changing the release bearing so I ordered a new slave cylinder kit as well - anything special about changing it?
21st Jan 2012 8:08pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2431 |
It is at lot of work. A bit tricky to get the belhousing-to-engine bolts. You may need a cardanic joint/extension. To remove the exhaust/cat is also a PIA. Tip: be careful not to break the protruding plastic tubing from the slave cylinder. Puma 110" SW
21st Jan 2012 8:51pm |
Short update - clutch changed. Car is doing great - no limp mode and pulls great from 1500 rpm all the way to 3200 rpm.
Regarding poor connections can anyone recommend something to clean connections with. Am planning to go over all connections in the engine bay. 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
3rd Feb 2012 10:09pm |
Christian, I use this stuff from CPC Farnell. K9F on here is a sparky and recommended it.
http://cpc.farnell.com/1/1/31082-electrolu...olube.html Brian. |
4th Feb 2012 8:26pm |
