![]() | Home > Maintenance & Modifications > ALARM /IMMOBILISER HELP |
glyn.c Member Since: 30 Oct 2011 Location: east devon Posts: 33 ![]() ![]() |
HI
can anyone help me with info on what might be the problem with my alarm/immobiliser on an 02 td5 please ? .When i lock it i get the standard 3 flashes of the lights but when i unlock i do not get the single flash ! everything is working as normal as far as the setting but its a bit annoying early mornings if i have not immobilised befor opening the door ![]() GLYN |
no not at all ! everything has been normal up to a couple of days back ,only thing thats been different was the battery needed charging due to lack of use ( been left sat for about 2 weeks ,probably needs a new battery though ,ill try a pulse tester and see what it says ,though its showing OK with the battery indicator on the battery ) but it worked ok after the recharge! ALL THE BEST
GLYN |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Change your battery in the handset. You will need 1 CR2032 battery for each handset. Get them on ebay and they are seriously cheap, genuine panasonic ones are about 25p each.
Pete. |
Quote from Owners Handbook for 2010MY Puma
![]() When the battery needs replacing, it will be apparent from the following symptoms: The remote control will only work every other operation when unlocking. The hazard warning lamps will not flash when the alarm is disarmed. Do not remove the battery until you are ready to install the replacement. LANDYWATCH ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Change the fob batteries first, if that doesn't cure it let us know and we will take it from there.
![]() Brian. |
driver Member Since: 02 Aug 2009 Location: bude , cornwall Posts: 206 ![]() ![]() ![]() |
Agreed, I had the same symptoms and changing the batteries has cured it ,all back to normal now.
thanks guys ! i will try that in the morning , it does sound about right though with the alarm disarming every 2nd attempt ! though the one fob is or should have been new a month ago when i bout the vehicle!.
This is the first vehicle i have ever owned where so much help and camaraderie is available from other owners,i was shocked after i picked it up and driving home EVERY other defender i saw waved!! (thought there was something wrong at first ![]() GLYN |
Ah yes the landy wave!
Not partaken in the new one yet as i feel concious of it's newness. maybe some mods and my PP will bring some love ![]() Great to here your enjoying it already. |
THANKS GUYS
SPOT ON ! what was interesting though was only one battery needed replacing and then the other fob started working ok again without a battery change ! the one that needed changing was on the NEW fob issued and programmed by a landy stealer just a month ago ![]() ![]() GLYN |
