Home > Maintenance & Modifications > ALARM /IMMOBILISER HELP
glyn.c
HI
can anyone help me with info on what might be the problem with my alarm/immobiliser on an 02 td5 please ? .When i lock it i get the standard 3 flashes of the lights but when i unlock i do not get the single flash ! everything is working as normal as far as the setting but its a bit annoying early mornings if i have not immobilised befor opening the door Embarassed ,i have tried both fobs and they are both the same,this has only recently started to happen .many thanks ! ALL THE BEST
GLYN
Post #110533 29th Dec 2011 10:38am
110SEB
I seem to remember that the flashes change to indicate that the batteries in the fob need changing. Have you found it difficult to lock remotely?
Post #110538 29th Dec 2011 10:58am
glyn.c
no not at all ! everything has been normal up to a couple of days back ,only thing thats been different was the battery needed charging due to lack of use ( been left sat for about 2 weeks ,probably needs a new battery though ,ill try a pulse tester and see what it says ,though its showing OK with the battery indicator on the battery ) but it worked ok after the recharge! ALL THE BEST
GLYN
Post #110540 29th Dec 2011 11:05am
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Change your battery in the handset. You will need 1 CR2032 battery for each handset. Get them on ebay and they are seriously cheap, genuine panasonic ones are about 25p each.
Pete.
Post #110542 29th Dec 2011 11:18am
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Quote from Owners Handbook for 2010MY Puma Thumbs Up
When the battery needs replacing, it will be apparent from the following symptoms:
The remote control will only work every other operation when unlocking.
The hazard warning lamps will not flash when the alarm is disarmed.
Do not remove the battery until you are ready
to install the replacement. LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #110586 29th Dec 2011 4:42pm
Lorryman100
Change the fob batteries first, if that doesn't cure it let us know and we will take it from there. Thumbs Up
Brian.
Post #110617 29th Dec 2011 6:35pm
driver
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Agreed, I had the same symptoms and changing the batteries has cured it ,all back to normal now.
Post #110620 29th Dec 2011 6:52pm
glyn.c
thanks guys ! i will try that in the morning , it does sound about right though with the alarm disarming every 2nd attempt ! though the one fob is or should have been new a month ago when i bout the vehicle!.
This is the first vehicle i have ever owned where so much help and camaraderie is available from other owners,i was shocked after i picked it up and driving home EVERY other defender i saw waved!! (thought there was something wrong at first Laughing ! still getting used to it ) ALL THE BEST
GLYN
Post #110638 29th Dec 2011 8:30pm
T1G UP
Ah yes the landy wave!
Not partaken in the new one yet as i feel concious of it's newness. maybe some mods and my PP will bring some love Thumbs Up
Great to here your enjoying it already.
Post #110641 29th Dec 2011 8:40pm
glyn.c
THANKS GUYS
SPOT ON ! what was interesting though was only one battery needed replacing and then the other fob started working ok again without a battery change ! the one that needed changing was on the NEW fob issued and programmed by a landy stealer just a month ago Shocked Shocked before i bought the vehicle from an independant ( or maybe i shouldn't be too shocked after reading about main stealer's on here !!) ALL THE BEST
GLYN
Post #110735 30th Dec 2011 10:38am
