Home > Puma (Tdci) > puma clutch
Page 2 of 3 <123>
ZeDefender
blackwolf wrote:
CRJ wrote:
The labour time 3.9 hours - is that what an authorized dealer is expected to use changing the clutch?? CRJ
No, it is the number of hours labour Landrover will pay the dealer for doing the work under warranty, and is generally less than the number of hours the job actually takes, and also generally less than the times listed in the official Repair Times Manual.
...which is why my piggin' dealer would rather try and sell me an Evoque than fix my new Defender Evil or Very Mad Tell someone you love them today because life is short.
Post #117396 21st Jan 2012 8:52pm
Myo
South Africa 2010 Defender 90 Puma 2.4 CSW Stornoway Grey
Ok, so just got an email off to the service manager, so like a electronic torpedo its on its way, have reported this but my 90 would just not perform when I took it to the dealer! Did take a vid and included the bulletin in my email so now waiting for a 'hit!' Twisted Evil
Post #151660 24th Jun 2012 5:41pm
tmcwhirter
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I have the same problem - clunks and rattle while clutch out in neutral.
Still under warrantee, but its been tuned... any thoughts on how I should handle this? Don't want to have warrantee declined etc
Post #154706 10th Jul 2012 10:28am
Naks
Tuned with a remap? Re-flash the original map before taking it to the stealer, that's what I do Thumbs Up --
Post #154707 10th Jul 2012 10:31am
tmcwhirter
Prob is that I don't have the original map or any of the kit... don't have any of the kit either. Anyone in London or home counties that can help me out and save my map, flash the original (or current version) and then reload???
Post #154708 10th Jul 2012 10:34am
JSG
Who did you get the map from? They should have the original for you. John
2011 Tdci 110 CSW XS
Post #154748 10th Jul 2012 3:14pm
The Friendly Lyon
Australia 2007 Defender 110 Puma 2.4 SW Fuji White
Resolving issues with Puma Clutch, flywheel...
G'day fellas. Over the weekend I was driving my 2007 Defender 110, when suddenly I couldn't select second gear. I pulled over to the side of the road and tried selecting first, then reverse. Nothing. Then wild rattle started to surge from what sounded like the gearbox. Soon after something grabbed when I again tried to engage the gears. I had to kill the engine to stop it. After finally shifting into low range and then high again, I managed to drive my truck home, however, the rattle remains.
I've since been reading the threads on various forums, including those here, detailing known issues with the PUma clutch. Despite my foraging, I still haven't located any advice around solutions for the problems. I've since taken my truck the the Land Rover specialists who service it. They have indicated they will need to remove the box to make a proper inspection and diagnosis but suspect it could be the flywheel. Early indication of cost if this is the problem are around AUD$3000.
Does this sound about right to anyone who may have had a similar problem? And, is this something that you might be able to DIY fix with the right parts and workshop manual?
Appreciate any advice anyone has...
Jethro
Post #157431 23rd Jul 2012 12:07pm
The solution is to replace the clutch with the newer version that's been modified to resolve this problem. There is lots of discussion about it on this forum, including pictures of the two types somewhere. Have a search Thumbs Up Darren
Post #157436 23rd Jul 2012 12:46pm
AlisterC
Wales 2011 Defender 90 Puma 2.4 XS CSW Indus Silver
I think the 2 types you mention are in a sticky at the head of the Puma section on here
Post #157465 23rd Jul 2012 2:39pm
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
FYI
One of our very relaible Indies, and I quote:
"just a heads up for the Puma owners
the clutch plate design is unfortunately "flawed" and the same reliability you would expect from any of the other LR clutch plates.
you are unlikely to get the same life and reliabiliy from the OE clutch in the Puma.
did extensive research in conjunction with Valeo and found the ultimate clutch (not the pressure plate!) from a Mazda TD to be a perfect match (would make sense as the Puma is essentially Ford based)
have done 2 so far and the customers are extremely satisfied."
Mmmm.............Mazda clutch is apparently an exact matc, just better???
Post #158272 27th Jul 2012 9:35am
MK
which Mazda TD truck would that be? Puma 110" SW
Post #158356 27th Jul 2012 5:38pm
Regard
Will try to find out and let you know!
Post #158460 28th Jul 2012 7:10am
DarrenJ
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Just had the clutch changed on mine, it had the same symptoms as yours, I originally thought it was the release bearing. When they took it apart the springs had broken up on the friction plate, truck is 12 mths old with 9000m. I had only had it a week! Crying or Very sad Darren
Post #158469 28th Jul 2012 7:59am
T1G UP
warrenty?
Post #158475 28th Jul 2012 8:11am
DarrenJ
Yes thankfully. Had only had it 1wk and purchased from a stealer too! Good servic from the dealer though who did the work (it wasn't the same as I purchased it from) and they did a load more work they found too. They did say its the first of that type of failure they'd seen on the new style clutches. Darren
Post #158479 28th Jul 2012 8:33am
Page 2 of 3 <123>
