Home > Puma (Tdci) > New Engine or Not new engine??
Charlie148
France 2007 Defender 110 Puma 2.4 SW Corris Grey
Hi all,
First time posting and not too much of a mechanic but hoping i could have your opinions on the below:
I have recently bought at auction in France from the fire brigade a 2015 2.2tdci 110 'with a broken engine' so they add said.
I received the car turned the key and the car turned over first time and runs very smooth alot smoother than my 2.4 tdci!
I first set out to go take the cylinder compressions as i was told by the chief mechanic of the fire base he reckons the piston rings have gone on it. That was a quick job not!!
Cylinder pressures:
Piston 1 300psi
Piston 2 300 psi
Piston 3 420 psi
Piston 4 400 psi
As i was getting to the glow plugs taking the exhaust manifiold off i noticed a sh*t load of oil in the intercooler rubber elbow, so next step stripped the intercooler and pipework and removed close to 1.5l of oil..
What did i find in the intercooler? Bits of turbo Big Cry ! So i took the turbo off ( this was replaced 1500km prior to me receiving the car for a new one)
I have dropped the oil and have found tiny bits of metal looks like aluminium in the filter Laughing .
What do you recommend i do next?
Bite the bullet buy a new block and rebuild it?
Get the head off and continue to look for metal?
Any other recomendations for next step as im getting to the end og my mecanical skills and not too sure how good i would be at getting the head off!
What would cause turbos to fail on this car especially one that has just been fitted?
Sorry about the long post!
Thanks
Charlie
Post #999852 13th Jul 2023 5:41am
LR90XS2011
If you brought it knowing the engine was XX, I would just bite the bullet and get a replacement, last time I looked Duckworth Parts site sponsor had a few, also many companies are now removing 2.2 Puma's and replacing them with other engines so there are quite a few removed engines appearing on the market.
If you had the skill and confidence and the tools stripping and rebuilding is an option but it is fraught with potential problems and you may find it is XX anyway and then you have just wasted your time. DEFENDER 90 TDCI XS,
Post #999860 13th Jul 2023 6:37am
NickMc
I’d take the rocker cover off and have a look, you’ve nothing to lose.They drop rockers and damage the cams mostly. I would avoid the aftermarket rebuild kits some of the quality of parts in them isn’t very good.
New engines are available from the likes of Turner Engineering - a complete second hand might be your cheapest option.
Post #999866 13th Jul 2023 7:37am
Dinnu
Bits of the turbo from the previously failed turbo, so means no one bothered to clean up, or the new turbo disintegrated? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #999880 13th Jul 2023 9:04am
hank
I would replace the external parts that need replacing, remove the rocker cover and sump and check/clean up swarf, flush out the galleries with oil and then just see how it goes.
Worst case scenario the engine dies a death, but this leaves you no worse off than now.
Best case scenario the engine is ok and you are quids in.
I would also replace the injector seals whilst you are at it. This could be one cause of low compression > 110 XS Double Cab
Post #999893 13th Jul 2023 11:25am
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
I agree with Hank.
I'd be inclined to give the existing engine a 'go' first, before going to the effort and expense of swapping it out.
Most of the bits that you'll clean/check replace would be reused if/when you change the engine, so the spent cost is probably worth it.
Post #999894 13th Jul 2023 11:35am
Dinnu
A blown turbo compressor should not find itself up in the rocker cover or sump unless they severely damaged the bore and caused the rings to scrape on the bore resulting is swarf in the oil sump.
I had a case of a blown turbo compressor, albeit on a much larger engine, and all (or at at least most) of the particles were caught by the intercooler. There was no apparent damage to the engine.
Low compression could also be caused by particles caught between the valve seats. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #999923 13th Jul 2023 2:17pm
hank
Yeah it should all be in the inlet/exhaust but since Charlie148 mentions that there are metal particles in the filter something has found its way into the oil system. No harm in giving it a clean > 110 XS Double Cab
Post #999932 13th Jul 2023 3:06pm
Dinnu
Missed that detail Thumbs Up 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #999936 13th Jul 2023 3:37pm
Turbo debris can quite easily find its way down the oil drain from the turbo to the sump.
Post #999958 13th Jul 2023 5:41pm
Charlie148
Thanks all for the advice!
Dropped the sump today and no sewed in there, took the rocker cover off and all looks clean with no scraping on anything! As Hank says minimal cost to rebuild compared to buying new so worth a shot!
Injectors have been sent off for testing, seals and washers on the shopping list thanks all really appreciate the advise!
Will keep you posted when I get it running again!
Post #1000021 13th Jul 2023 10:07pm
