Home > Td5 > axle id number/sn
olistr
Germany
axle id number/sn
Hi,
I am trying to identify my axle type, the only number I found is on top of the Axle on the little square moun, nothing at the location where LR Workshop indicates, which means at the back left side facing backwards. However the first 3 digits do not match any of the axle types listed on the lr workshop site, any idea if this is the correct number and or if there are other locations the number could be or if there are more axle type numbers that the ones listed on lr workshop?
See the pics here
Post #999640 11th Jul 2023 3:37pm
rallysteve
The axle number is stamped on the axle casing tube. Its quite hard to spot if the axle is rusty or heavily painted though as its only dot punched.
Diagrams on LR workshop show locations: https://www.lrworkshop.com/axles-differentials/axlecodes 02' 110 TD5 Double Cab Rebuild Thread
Post #999651 11th Jul 2023 6:42pm
olistr
Germany
could it be it rusted away?
cause I blanked the back and front axle where lr works says they should be and could not find anything.
As you can see on the third picture, if it was there, I should see it, no?
Post #999658 11th Jul 2023 7:18pm
Why do you need the axle number? What are you trying to find out?
Post #999668 11th Jul 2023 8:19pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
Earlier axle cases were full number stamps, not dots.
Both my axle cases were rusted to the extent that no numbers existed. I changed my rear axle case as it was cheaper (and made a better job) than replacing the various rusted brackets. The replacement was from a 300tdi discovery - that had full numbers.
I also replaced the front axle case as I got one for the right price (£100 and it was like new). I believe this was from 300tdi defender (but not 100%) and I had to change to the wider radius arms as my original case was a 200tdi 10 spline. The new case has its number via dot matrix.
Not sure when they changed, but obviously they did!
I DO APOLOGISE, I HAVE JUST NOTICED THIS IS IN THE TD5 SECTION SO I WOULD EXPECT YOUR NUMBER TO BE DOT STAMPED SO MORE LIKELY TO BE AFFECTED BY RUST. I HOPE I HAVEN'T CONFUSED THINGS 😕
Post #999673 11th Jul 2023 8:51pm
Mossberg
Also beware that whilst you may get an axle build type from the number, that build may have been altered by the replacement of parts. The older your vehicle is the more chance there is that what you have is not original!
There is a lot of knowledge on this forum, so also ask questions on here about your axle as hopefully you will get the help to repair/restore your vehicle.
Post #999677 11th Jul 2023 9:04pm
NickMc
It’s a Salisbury from the looks of it?
Post #999681 11th Jul 2023 9:17pm
olistr
Germany
I was trying to be lazy and find out weather it is a 13s or a 63s to know if it would have the hole for the ABS Sensor Bushing. I guess I'll find out when I dismantle it.
It is indeed a 130 TD5 from late 2002
Thanks all for the help so far.
Post #999699 11th Jul 2023 10:04pm
NickMc
Should be able to tell from looking at the backing plate, axle end even maybe if you take a picture.
Post #999700 11th Jul 2023 10:07pm
olistr
Germany
Hi NickMc,
I know the defender does not have ABS, so the backing plate probably will not tell me, or will it? I was more interested if it would be ABS ready.
Post #999704 11th Jul 2023 10:22pm
NickMc
Wrong side, but there should be a round hole opposite side of the two calliper bolt mounting lugs.
Post #999709 11th Jul 2023 10:39pm
