Home > Td5 > Disco 2 electric window switch the same?
DC101
United Kingdom 2003 Defender 110 Td5 DCPU Epsom Green
Hi,
The Electric window switch just drops the window but not back up again.
Looking at used on flea bay and found a disco2 switch. Looks identical to the Defender with same number.
Just would like to verify if anyone knows.
New are silly money.!
Thanks.
Post #999593 11th Jul 2023 9:14am
geobloke
The electric window switch was used in the Freelander 1, Defender TD5 and Discovery TD5 are all the same.
There was a part number change around 2002/2003 and the later TD5 and TDCI/Pumas share the same switch part number. But, they are interchangeable.
YUF101521LNF Early
YUF101520LNF Later
It is possible that they may be slightly different colours too, early being grey and later being darker, but I cannot confirm that.
Post #999594 11th Jul 2023 9:31am
DC101
Great. Thanks for confirmation.
Cheers,
Post #999598 11th Jul 2023 9:54am
Merlin
Are you sure it is the switch? Common fault is a broken wire in the door jam. Peter
Post #999607 11th Jul 2023 11:06am
DC101
Yes thanks, swapped switches over and it worked fine.
Ordered for £6.99 on ebay. Fingers crossed it works!
Post #999714 11th Jul 2023 10:52pm
