Home > Td5 > Disco 2 electric window switch the same? |
The electric window switch was used in the Freelander 1, Defender TD5 and Discovery TD5 are all the same.
There was a part number change around 2002/2003 and the later TD5 and TDCI/Pumas share the same switch part number. But, they are interchangeable. YUF101521LNF Early YUF101520LNF Later It is possible that they may be slightly different colours too, early being grey and later being darker, but I cannot confirm that. |
11th Jul 2023 9:31am |
DC101 Member Since: 01 Jul 2012 Location: Pudsey, West Yorkshire Posts: 260 |
Great. Thanks for confirmation.
Cheers, |
11th Jul 2023 9:54am |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 980 |
Are you sure it is the switch? Common fault is a broken wire in the door jam. Peter
11th Jul 2023 11:06am |
Yes thanks, swapped switches over and it worked fine.
Ordered for £6.99 on ebay. Fingers crossed it works! |
11th Jul 2023 10:52pm |
