Home > Maintenance & Modifications > Towing Electrics |
scotia Member Since: 29 Oct 2014 Location: North Cambs Posts: 96 |
Can anyone tell me the part number for the tow electric 12n wiring kit for a my15 110 please?
18th Nov 2014 6:08pm |
I can't understand why if LR designed this hole for this purpose they didn't amend the fitting instructions for the towing electrics kit accordingly. I thought the smaller hole through the centre was a necessary access hole to reach a bolt for the fuel tank or something? |
19th Nov 2014 10:48am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6612 |
Land Rover accessories site has the part numbers: http://accessories.landrover.com/gb/en/def...ng/towing/
Dan @ Duckworths (site sponsor) will supply at a good discount: duckworthparts <- click me 1988 90 Td5 NAS soft top 2015 D90 XS SW |
19th Nov 2014 11:41am |
Thanks for that information Martin and in particular regarding Duckworth prices.
19th Nov 2014 2:38pm |
pmason1973 Member Since: 28 Feb 2022 Location: London Posts: 4 |
Jammer600, it looks great. How did you attached the plug to the cross member? Thanks, Paul |
6th Jul 2023 1:46pm |
The easiest way is to install some rivnuts:
Click image to enlarge You can see how I did mine here: https://www.defender2.net/forum/post879215.html#879215 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
6th Jul 2023 1:51pm |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 825 |
https://irbdevelopments.com/
These guys do a plate that only needs 2 fixings to get it on then the electrics bolts to that. Wanted one when I fitted mine but could not get it in time. Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
6th Jul 2023 5:05pm |
To be honest, that seems like complete overkill (and expensive) for what is a pretty easy installation anyway Darren
6th Jul 2023 9:34pm |
My tow electrics have been taken off and I can't find where the plug is in the wheel arch to re-attach. Can anyone point me in the right direction, is it in the rear drivers side wheel arch? Many thanks, Paul |
7th Jul 2023 11:52am |
Norfolk-n-chance Member Since: 01 Sep 2019 Location: Usually in the garage! Posts: 80 |
Hi Paul
Yes, the socket is at the top slightly towards the back of the drivers side rear wheel arch. Under a flap. I can’t remember if you fold the flap or have to remove it….. Someone will know.. “a committee is a group of people who individually can do nothing, but as a group decide nothing can be done.” |
7th Jul 2023 12:40pm |
The flap is a piece of stiff plastic and is designed to protect the back of the lights from wheel spray. It's held in place with a couple of screws into spire nuts, both of which tend to rust solid unfortunately. It's common to have to drill them out and if you do, then replace them with something made of stainless.
This picture is of the other side with the flap removed but you can see the fixing points along the top edge: Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
9th Jul 2023 2:16pm |
