Home > Puma (Tdci) > Rear door not opening |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2414 |
I am in the same boat. I suspect the internals need dismantling. Puma 110" SW
6th Jul 2023 11:19pm |
drivetrainshunt Member Since: 27 May 2023 Location: Surrey Posts: 13 |
I’ve just been out and done a little bit of investigation. It opens fine from the inside. Guessing it is whatever the outer handle attaches to, it’s just not quite moving things enough.
Is there a known easy repair for this? Assuming if I disassemble the mechanism, I might be able to put thing a back in the right place? |
8th Jul 2023 11:11am |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4654 |
Is the child lock accidentally activated? 1982 88" 2.25 diesel
8th Jul 2023 1:04pm |
Child locks work the other way around, i.e. stops it being opened from the inside. Darren
110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 9th Jul 2023 3:54pm. Edited 1 time in total |
9th Jul 2023 2:50pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
Maybe same issue as this: https://www.defender2.net/forum/topic86427.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
9th Jul 2023 3:42pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1624 |
Worth squirting a bit of lube inside it, they just get tired and worn out though.
9th Jul 2023 5:06pm |
Tried stripping apart, cleaning and lubricating. Rear handle still not providing enough movement to fully disengage latch.
Ordered new part from Masa 4x4. They’re not super speedy are they! |
12th Jul 2023 9:13am |
