Home > Technical > sandblasted
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
sandblasted
I'm going toget my chassis sandblasted for my 90 rebuild and want some info for painting it.
Option 1 is to etch prime it and undercoat + paint it with 2k auto paint.
Option 2 is epoxy prime and paint with 2k.
Which would you think is better.Galvanising is not an option here. Puma 110 SW
90 V8 SOFT TOP
Post #99882 14th Nov 2011 3:33pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Stove enamel Thumbs Up
Post #99901 14th Nov 2011 4:40pm
I'd go for a zinc rich primer such as Unidox followed by an enamel top coat such as Woco Supercote. Provides a very tough finish. Darren
Post #99905 14th Nov 2011 4:56pm
Zagato
Acid convert any surface residual rust after blasting and one layer of POR-15 you won't see rust again. Don't forget it's equally as important to treat the inside of your chassis with a spray rust converter and cavity application Thumbs Up
Post #99910 14th Nov 2011 5:43pm
LESVOSD110
They came to do a test and sprayed a type of liquid after (acid) and a week later with the chassis been outside,there is no sign of rust. Puma 110 SW
90 V8 SOFT TOP
Post #99918 14th Nov 2011 6:19pm
BigMike
blast it then quickly paint it with Tetrosyl chassis paint. no need for primer or etcher.
you mustnt wait long to paint it after its been blasted, try to do it same day.
Post #99922 14th Nov 2011 7:07pm
POR 15 is good stuff, but bear in mind that it's not UV stable so needs to be covered up if it's going to be a rolling chassis for any length of time. It's also not the best choice for the exposed rear crossmember. Darren
Post #99929 14th Nov 2011 7:26pm
Zagato
You can get POR-15 that is UV resistant Thumbs Up It really is the best stuff on the market at the moment, can be got from Frosts.co.uk Thumbs Up
Post #99930 14th Nov 2011 7:29pm
(scuttles off to Google it)
Oh yes, so you can Rolling Eyes It's been a while since I last looked at it for this application.
I still prefer a nice, heavy, zinc-rich primer though Smile Darren
Post #99935 14th Nov 2011 7:38pm
LESVOSD110
Epoxy primed the chassis today.Looks sweat,but took me 2 hours to spray as the little hidden cavities were trying to get the better of me.I won though. Puma 110 SW
90 V8 SOFT TOP
Post #101686 22nd Nov 2011 5:38pm
