![]() | Home > Puma (Tdci) > Beefier 12V source. |
Hella plugs (and sockets, of course) will be up to that task.
It's a real shame that we have this legacy of cigarette lighter sockets, as Hella plugs are far more robust. There are far too many phone/sat nav moulded chargers around to make a wholesale swap a practical proposition though, unfortunately. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
I will HAVE to keep the cigarette socket as you say phone charger, ipod, Surefire charger all use that style. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Previously I swapped out to a Hella socket and made up an adapter lead to convert the Hella to Phone charger socket.
I used the Hella for most things (I changed plugs where possible on leads) and the adaptor where needed. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
any pics of a hella plugs / socket thing?
Google is your friend
![]() ![]() ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 ![]() ![]() ![]() |
personally, i used the hella type and they didnt convince me
switched to speakon connectors for all heavy appliances long tim eago and am totally happy with them. ![]() made to last, lock in place, rated at 30 amps, 4 wire and widely available at every PA/sound shop. Neutrik also does a power connector version which have the same design but are rated a bit higher. even more expensive and my experience the speakon works as well. the only thing i do is solder the sockets instead of using the faston connectors. Dont like the vibrations in a car to trust the crimp connectors too much. 2 cents ![]() |
not for me |
Standard 12 volt sockets are rated at 16 or 20 amps.
Now is that a continuous rating or a short term rating? Thinking of its use as a cigar type socket it draws maximum power for a short period of time (less then 1 minute) then cuts out. So will they cope with 20 amps continuous?? The hella type plug and socket for a fridge typical draw about 3 amps so far never had a problem with it. The standard Hella plug is more vibration resistant then normal 12 volt plug. If you want a high current draw how about small Anderson connectors such as SB50. Rated at continuous 50 amps. Brendan |
