Home > Puma (Tdci) > Beefier 12V source.
RED-DOT
Beefier 12V source.
I use the cigarette lighter socket with a 8amp "Durite" male plug and it drives a Lightforce 100W roof lamp. I have the lamp fitted to an Army aluminium sunroof and the whole unit can be removed in a minute... The plug after a few uses seems to heat up and melt at the contact pin and was wondering what type of plug is more suitable for the power draw? I have seen the DIN plugs and may go down that route unless you know of a more robust set up?
Thanks. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #99852 14th Nov 2011 11:25am
Hella plugs (and sockets, of course) will be up to that task.
It's a real shame that we have this legacy of cigarette lighter sockets, as Hella plugs are far more robust. There are far too many phone/sat nav moulded chargers around to make a wholesale swap a practical proposition though, unfortunately. Darren
Post #99860 14th Nov 2011 11:56am
RED-DOT
I will HAVE to keep the cigarette socket as you say phone charger, ipod, Surefire charger all use that style. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #99864 14th Nov 2011 12:08pm
JSG
Previously I swapped out to a Hella socket and made up an adapter lead to convert the Hella to Phone charger socket.
I used the Hella for most things (I changed plugs where possible on leads) and the adaptor where needed. John
2011 Tdci 110 CSW XS
Post #99866 14th Nov 2011 12:20pm
T1G UP
any pics of a hella plugs / socket thing?
Post #99934 14th Nov 2011 6:36pm
Google is your friend Smile
 Darren
Post #99936 14th Nov 2011 6:45pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
personally, i used the hella type and they didnt convince me
switched to speakon connectors for all heavy appliances long tim eago and am totally happy with them.
made to last, lock in place, rated at 30 amps, 4 wire and widely available at every PA/sound shop. Neutrik also does a power connector version which have the same design but are rated a bit higher. even more expensive and my experience the speakon works as well.
the only thing i do is solder the sockets instead of using the faston connectors. Dont like the vibrations in a car to trust the crimp connectors too much.
2 cents
Smile
Post #99945 14th Nov 2011 7:26pm
T1G UP
not for me
Post #99947 14th Nov 2011 7:32pm
leeds
Standard 12 volt sockets are rated at 16 or 20 amps.
Now is that a continuous rating or a short term rating?
Thinking of its use as a cigar type socket it draws maximum power for a short period of time (less then 1 minute) then cuts out. So will they cope with 20 amps continuous??
The hella type plug and socket for a fridge typical draw about 3 amps so far never had a problem with it. The standard Hella plug is more vibration resistant then normal 12 volt plug.
If you want a high current draw how about small Anderson connectors such as SB50. Rated at continuous 50 amps.
Brendan
Post #99968 14th Nov 2011 9:13pm
