![]() | Home > Maintenance & Modifications > Transfer Case Prop bolt removal |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17727 ![]() ![]() ![]() |
The trick is to remove the flange and circlip!
If the bolts are in good order they can be reused indefinitely. Although ideally the stiff nuts should not be reused, provided that they are still stiff they can. You should get at least a couple of removals from them. |
John P Member Since: 26 Dec 2013 Location: West Sussex Posts: 346 ![]() ![]() ![]() |
Thanks for the reply. Yes the bolts are in good shape. I have bought a kit, so will just use the new nuts.
