geobloke
Re: Driver’s Door Lock Button can’t be locked | |
Bobbydazzler wrote:Hi - picked up my 2011 90 this morning, and delighted with it, but one small problem.
The car central locks using the fob, but the drivers door button goes down then pops back up. It can’t be manually pushed down fully either. Door barrel appears to be seized and can’t be turned.
I’m assuming an issue with the mech inside the door, but as I prepare for my first Defender repair, any advice very gratefully received!!
Thanks in advance.
It is known for these lock barrels to corrode internally and seize. The alternative explanation is that there has been a screwdriver inserted into the lock and mangled it (as has happened with Miffys lock). The only solution is to replace the door lock.
It is also a good opportunity to check over the other linkages in the door and perhaps to add some sound proofing in there too.
17th Aug 2023 2:18pm |
