Home > Technical > Driver’s Door Lock Button can’t be locked |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5665 |
Is it definitely closing fully. Have you tried operating the latch by hand (tool) to make sure the latch is going fully round (2 clicks) then operating the CL.
1st Jul 2023 3:33pm |
Matt_H Member Since: 19 Sep 2018 Location: Cornwall Posts: 42 |
There is so much play in the "heath robinson" linkage contraption you will find behind the door card that if it gets a bit stiff in places there will be an attempt for the solenoid/actuator to move things, but it just won't have enough "pull" to achieve it. If you take the door card off you'll see what needs a bit of grease and where - also I tend to give the solenoid a bit of wd40 as well.
Not a difficult job. Last edited by Matt_H on 18th Aug 2023 9:18am. Edited 1 time in total |
17th Aug 2023 1:18pm |
It is known for these lock barrels to corrode internally and seize. The alternative explanation is that there has been a screwdriver inserted into the lock and mangled it (as has happened with Miffys lock). The only solution is to replace the door lock. It is also a good opportunity to check over the other linkages in the door and perhaps to add some sound proofing in there too. |
17th Aug 2023 2:18pm |
