Home > Maintenance & Modifications > Clutch failure. Whilst in Spain!
The Monkey
Ireland
So with absolute zero warning my clutch gave up the ghost. Whilst in Spain starting a 6 week tour. Anyhow I can't get any gears with clutch depressed but weirdly clutch peddle feels normal. I'm trying to find someone to do it for me but on the off chance could it be anything else! I've looked at all the obvious things fluid etc etc.
Has anyone driven any distance with out a clutch and started it in gear. Thankfully I'm off the main road.
Tristan
Post #997571 26th Jun 2023 1:14pm
MK
So, if you crank it in gear, the vehicle moves? Trying to rule out the gearbox output shaft adapter if it is indeed a Puma. Puma 110" SW
Post #997572 26th Jun 2023 1:21pm
The Monkey
Ireland
Yes thanks for reply! I moved it back into the shade about an hour ago😅
Post #997576 26th Jun 2023 1:31pm
MK
OK
Yes, you can drive without the clutch but it is stressful and a bit dangerous I would say.
I guess your only option is to find a decent clutch kit and replace it. In this forum you will find numerous threads about clutch failures and how to proceed+ infamous gearbox adapter.
EDIT. From the pictures on your gallery I see it is not a Puma Puma 110" SW
Post #997577 26th Jun 2023 1:41pm
Dinnu
Can you get any gear in with the engine off? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #997581 26th Jun 2023 1:55pm
The Monkey
Ireland
Yes with engine off no problem. Clutch in or out
Post #997587 26th Jun 2023 2:08pm
geobloke
What engine and gearbox do you have? IS it a pre TD5? thinking TDI clutch fork/pivot...
EDIT: ignore that, if your pedal feels ok then it isn't the fork as usually the pedal sticks to the floor and does not rise.
Post #997593 26th Jun 2023 2:55pm
Re: Clutch failure. Whilst in Spain!
The Monkey wrote:
...Has anyone driven any distance with out a clutch and started it in gear...
Yes, many times, it's not difficult. Starting and stopping is a pain and to be avoided if possible but when moving the clutch really isn't needed. It helps if you drive hire cars a lot in your youth since they are ideal for practicing.
Most rally drivers back in the day drove without using the clutch since it allows the right foot to be on the accelerator and the left foot on the brake, but this is a more advanced technique and not one for beginners.
Post #997618 26th Jun 2023 6:57pm
The Monkey
Ireland
Sorry i didn't reply its actually a 2.4tdci puma. I must update my bio.
Post #997861 28th Jun 2023 11:35am
SteveG
2005 Defender 90 Td5 CSW Belize Green
Pop it into 1st and low range, then you can start it in gear, and then once moving you can change up into high range.
You’ll be surprised how soon you get used to adjusting the revs and whilst applying slight pressure on the gear stick sliding it into the gear you want at the appropriate revs. Taking it out of gear is even easier, again apply slight pressure as you lift off and as soon as revs match it will pop out of gear.
Post #997865 28th Jun 2023 11:59am
The Monkey
Ireland
I got it recovered in the end. Wasn't worth any risk suspect the clutch release bearing is goosed😫.
Post #997867 28th Jun 2023 1:10pm
SteveG wrote:
Pop it into 1st and low range, then you can start it in gear, and then once moving you can change up into high range. ....
Personally I would not recommend first low, since changing from low to high on the move even with the clutch is something many people have trouble with. Besides first gear (high range) is quite low enough to start the engine on any Defender or series LR, and especially so on the MT82 with it's wonderful low first.
If, like me, you habitually double-declutch all gear changes, both up and down, (which I realise is slightly unlikely Laughing ) it's even easier since you can generally drive normally with the clutch pedal not doing anything when you press it and the gear changes will be smooth and quiet.
Post #997870 28th Jun 2023 1:17pm
The Monkey
Ireland
I started in low to move it 300ft. In first gear. It seemed to be easy to get moving and less pressure on the system.. I had it recovered though..
Post #997875 28th Jun 2023 2:15pm
Mr Fox
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Is it at a local garage? Have they given you timescales as to when you can resume your holiday?
Fingers crossed for you that you can get up and running soon. Thumbs Up
Post #997885 28th Jun 2023 4:02pm
The Monkey
Ireland
4x4 specialist in Zaragoza. Currently talking gearbox out so tomorrow or Friday hopefully 😬
Post #997929 28th Jun 2023 9:42pm
