![]() | Home > Technical > Steering wheel question |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 519 ![]() ![]() ![]() |
Maybe undo the nut and count the splines.
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 ![]() ![]() ![]() |
Rivarama Member Since: 28 Aug 2021 Location: London Posts: 155 ![]() ![]() ![]() |
Tried that and it is properly stuck! Hence the question ![]() |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 761 ![]() |
Are the two holes next to the shaft threaded? If so make a puller with a flat bar and a central bolt to screw against the shaft.
I have one for series 111 steering wheel somewhere |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1679 ![]() ![]() ![]() |
Looks like 48 spline from the part number.
You’ll need a puller easy to make as above or just maybe leave the nut on and give it a proper tug. |
Nut should come of with reasonable force, getting the wheel off requires a puller, like others I made one. Once the nut is off splines can be counted. Good luck!
Just ordered a pulling tool from eBay. Hopefully that should do it. Thank you
tommac Member Since: 03 Jul 2018 Location: devon Posts: 26 ![]() ![]() ![]() |
Worth applying some release agent as well- plus gas or similar and let it soak for a few days!
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5239 ![]() ![]() |
That looks very much the same wheel as my TD5, which is a 36 spine ![]() Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
I bought a £10 puller tool on eBay for that purpose, and managed to take it out fairly easily. I am happy I did as it turns out to be an early TD5 SW and indeed came as a 36 splines.
Now off to buy myself a nice replacement wheel… pics to follow |
Ok - I fitted the new wheel, I have to say I am very happy with the result…
![]() Click image to enlarge ![]() Click image to enlarge |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
Very jazzy
@FD7
I have tried to reply to your PM many times, they get stuck in my outbox. Don’t get why. Sorry. Email me again if you want |
Id switch that boss to a removerable one,
