Home > Technical > Steering wheel question
Rivarama
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zermatt Silver
Hello,
Is there a way to tell whether my steering wheel is 36 or 48 spines without removing it?
The part number reads NTC3633 which according to google results points to a ranger roger classic.
I have tried to wrestle with it and can’t seem to take it off either.
Is there anything like a simple job on those cars?!?!
Post #995872 11th Jun 2023 7:31am
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
Maybe undo the nut and count the splines.
Post #995874 11th Jun 2023 7:58am
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
Post #995875 11th Jun 2023 8:00am
Rivarama
Tried that and it is properly stuck! Hence the question Wink
Post #995879 11th Jun 2023 8:31am
gcc130
Are the two holes next to the shaft threaded? If so make a puller with a flat bar and a central bolt to screw against the shaft.
I have one for series 111 steering wheel somewhere
Post #995883 11th Jun 2023 9:14am
NickMc
Looks like 48 spline from the part number.
You’ll need a puller easy to make as above or just maybe leave the nut on and give it a proper tug.
Post #995897 11th Jun 2023 1:21pm
MarkBrown
Nut should come of with reasonable force, getting the wheel off requires a puller, like others I made one. Once the nut is off splines can be counted. Good luck!
Post #995902 11th Jun 2023 2:21pm
Rivarama
Just ordered a pulling tool from eBay. Hopefully that should do it. Thank you
Post #996070 12th Jun 2023 9:56pm
tommac
United Kingdom 2001 Defender 110 Td5 DCPU Alveston Red
Worth applying some release agent as well- plus gas or similar and let it soak for a few days!
Post #996599 17th Jun 2023 10:06am
Procta
Re: Steering wheel question
Rivarama wrote:
Hello,
That looks very much the same wheel as my TD5, which is a 36 spine Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #996691 18th Jun 2023 12:13am
Rivarama
I bought a £10 puller tool on eBay for that purpose, and managed to take it out fairly easily. I am happy I did as it turns out to be an early TD5 SW and indeed came as a 36 splines.
Now off to buy myself a nice replacement wheel… pics to follow
Post #996776 18th Jun 2023 6:21pm
Rivarama
Ok - I fitted the new wheel, I have to say I am very happy with the result…
Post #997192 22nd Jun 2023 9:29pm
Screbble
Very jazzy Thumbs Up
Post #997195 22nd Jun 2023 9:38pm
Rivarama
@FD7
I have tried to reply to your PM many times, they get stuck in my outbox. Don’t get why. Sorry. Email me again if you want
Post #997414 24th Jun 2023 10:26pm
Procta
Id switch that boss to a removerable one, Thumbs Up Wheel looks nice mind! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #997424 25th Jun 2023 12:51am
